Click here to Donate
Low speed fan problem..
Hi guys,
I have a C2 with two rad.
One of the fans is not working on low speed, however it works on high speed.
I have read that there are four relays [Relays 19 and 21(low) and 20 and 22(high)] - where are these located?
I need to swap out relays and find out if it is a faulty relay or a fauly fan.
Thanks in advance.
J
Hi guys,
Thanks in advance.
J
I have the same problem and searched the forum to no avail. My manual says "see qualified technician for relays" and has no info on the layout/schematic of the relay holder. If the fan works on "high", I would think it the relay or the ballast resistor. I will be watching for a reply.
James
James
Hi James,
I have just located the relays, they sit under the dash (drivers side).
However not sure what relay does what.
And as you say it may well be the resistor, which I assume sits on the fan unit?
J
James
Hi James,
J
The resistor is mounted under the fan unit (one on each side), do a search for "ballast resistor" and you will find a thread with pictures showing the resistor location. I know where the relays are located, I don't know which relay corrosponds to the fan speeds either.
James
If it is a similar set-up to the 986, I would consider the aforementioned resistor. I only just learned this. I didn't know the a/c fan had two speeds, my mechanic informed me that the low speed was not working because of a blown series resister, which he replaced. He said it is behind the front bumper somewhere, it was about 5 inches long and about .75" in diameter with two wires coming out of one end.
