I had the opportunity to drive my brother in laws stock S2000. Nice car. The one element I found signigicantly better than my 986 was the shifting: smoother and shorter throws.(the shifter must be directly atop the trans or linked by rods). I don't imagine a short shifter would help with the smoothness of our cable driven 5 spd trans. Two questions:
-Should I go name brand short shifter or are the knock offs ok? No track for me.
-I've lubed the gear accuators on the trans. Other than that, is there any way to make shifting smoother? On motorcycles we lube all the cables by forcing essentially WD40 into the lines. However the 986 cables are heavly insulated in the engine bay.
Am I expecting too much from a short shifter?
I don't have a short shifter but can say a lot of people have been very happy with the eBay short shifters that sell for about $80. The reason I have not installed one, is because I've heard they make shifting rough.
ekam or anyone else,
Do you know if the part you referenced from Suncoast is OEM or aftermarket (looks to be OEM)?
The reason I ask is that I cannot figure out why a complete 997 assembly is cheaper than a B&M shifter only? Seems like too good to be true.
I am looking to replace my boot and shifter soon. While I am at it, I might as well try the 997 shifter as I am also in search of smoothness and shorter throws is a plus.
I know nothing of Suncoast as I usually order from Sunset Imports. I have heard good feedback from both vendors on this site.
Kind regards,
Halo
This is a great question that got me wondering as well.....
Is the 987 assembly much superior to the B&M? If so in what aspects?
I installed a B&M two months ago and it does feel a bit stiff, but I love the short throws it gives. Had I known of the 987 assembly I would have sold my B&M online and bought the OEM piece - that would have allowed me to keep my original part (986) intact and simplified the installation since there is no need to brake the shifter from the base.
What is the difference between the two and why is the OEM cheaper?
All the best,
Gus
Edited by gandrade1
Okay, I just ordered a 997 shifter assembly today from Sunset Imports ($161) as well as some other parts.
They said that customers have been ordering these quiet a bit latley. He has heard from customers claiming a smoother shift than the stock shifter.
like Baconaire said "Looking for smoothness more than anything" and a little shorter throw wouldn't hurt.
I'll probably put it in next month while I am on vacation. I'll post my results.
Halo
I assume its the shifter base which has created the change in feel of the shifter for the 997 and 987 shifter.
Is it assumed that you could use this new base combined with one of the replica Ebay short shifters to gain both the shorter throw, and the improved shift action that the updated base provides? Would this solve both issues?
Based on what?
Based on what?
wow, tough crowd here......
uh, based on the fact that ive read that the shifting mechanism has changed. Its not just a lever or geometry change but that part of the overall console design was changed. What EXACTLY that entails, well im not so sure.
I said i assume, i was asking a question, hardly stating fact. I don't have both in hand to compare, but I am curious so i figured i would ask.
Cheers
Based on what?
Cheers
Hi Ryan,
I asked because it looks like you are on to something...
I recently installed the B&M, and it does feel stiff despite the perfect throws. If what you are saying is correct then you might just have found the perfect solution!
And I will be lining up for the 987 assembly too :cheers:
Best,
Gus
Edited by gandrade1
In response to why B&M cost more $. It's because they can (charge more) as they're the only guys around that makes these short shifters. In additon their shifter is made of stainless steel and aluminum which cost more to make.
I see on Suncoast's site that it lists years 1997 - 2004.
Does that mean that this will work with 5 speeds too?
Yes, there is no difference between the 5 speed and 6 speed shifters.
  • 2 months later...
I popped off my shifter knob and used a grinder to lop off 1" of my stem. I then matched the notches so the shifter knob would seat correctly. Popped the shifter knob back on and now I have a "short shifter". No muss, no fuss. It shifts the same as it did before. I've even considered taking another 1" off the stem but the leather shroud is pretty bunched up as it is now.
To do it I draped off the interior of the car with about four layers of thick canvas drop cloth. Be sure to monitor where your sparks are being sent. I burned through a couple layers of the drop cloth pretty easily. Match the existing bevels and notches and you are good.
Later,
-pvaughan
