So the car pulled a P0456 code today "Very small evaporative system leak"
Can I assume this is just a loose gas cap that I needed to tighten? Looking for most common reason for this code.
I cleared it today. IF it is not a loose gas cap and it's something more - when should the check engine light return?
P0456 Fuel Tank Ventilation System (Minor leak) - Below Limit
Possible fault cause
- Tank cap seal
- One or several leaks in fuel tank ventilation system
Check the o-ring on the gas cap too.
In a few rare cases the EVAP canister purge valve cracks or leaks.
- Tank cap seal
Loren - thanks for this.
You don't happen to have a part number handy and a place I can buy a replacement gas tank cap do you?
- Tank cap seal
US car?
If so, use 996.201.241.03 Fuel tank cap w/ clip -- US MSRP $13.07
or
go all out with the optional aluminum look cap 997.201.980.00 -- US MSRP $163.39
  • Like 1
- Tank cap seal
Wait I think i found it.
The car is an 02. maybe I will just replace this as a preventative
http://www.bestsourceautoparts.com/partsCa...ageFrom/catalog
So I ended up replacing the gas cap.
The old one had a lot of cracks and splits in the Oring. TERRIBLE quality.
Does anyone have hints how to reinstall the strap?
  • 3 years later...
- Tank cap seal
Experienced this code and tried a new gas cap; just got the code again this past weekend.
Is there a method by which I can isolate which part of the ventilation system is leaking or just 'pick-and-replace' until I get the right one?
Tim
2003 996 C2 Cabriolet
Edited by tac27
There are some other tests you can run with Durametric, a PST2, PIWIS tester to further diagnose the problem area.
Loren,
Could you please tell me which test I can run with the Durametric and what I should be looking for? I ran everything I saw that looked remotely linked to the fuel system. Biggest challenge is I'm not familiar with what I should be looking for to detect a leak.
Loren,
I would take it to your local Porsche shop and tell them that you've replaced the gas cap but you suspect a leak in the fuel tank ventilation system.
If they have a PIWIS they can do a leakage test and pinpoint the problem - a frequent culprit is the fuel tank ventilation system which
If you are a DIY person read this: http://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/106-FUEL-Replacing_Your_Fuel_Line_Vent_Valve/106-FUEL-Replacing_Your_Fuel_Line_Vent_Valve.htm
Edited by roadsession
Loren,
Thank you roadsession.
I would prefer to learn how to find the leak with the Durametric, which I purchased so I wouldn't have to take the car to the shop.
Again, if anyone is familiar with how to do this with the Durametric, I'd really appreciate it if you could share that process.
Loren,
The Durametric can tell you that you have a leak, finding it requires other diagnostics (smoke machine, individually testing various devices with a handheld vacuum pump, etc.). The Durametric is like a compass rather than a GPS, it can point you in the correct direction, but it cannot always pinpoint what needs to be addressed; that is up to the diagnostic skills of the operator.
As Loren already pointed out: "P0456 Fuel Tank Ventilation System (Minor leak) - Below Limit Possible fault cause - Tank cap seal - One or several leaks in fuel tank ventilation system Check the o-ring on the gas cap too. In a few rare cases the EVAP canister purge valve cracks or leaks."
