Hi all and thanks ahead of time.
I am not going to use my 1999 C2 996 in the winter. I have changed the oil. I would like to hook up my Battery Tender to it.
any advice on where to hook it up? Book says to the battery but I'm thinking of putting it where jumper cables should be attached.
Appreciate any help
Contact Deltran customer service and see if anyone near you sells the cigarette lighter adapter. Chances are nobody does and odds are good they will just send you one as goodwill. Then just connect it to your cigarette lighter plug, which works the best. There's a notch in the bottom of the driver door rubber seal to route the maintainer cable through. Or you could always order one through Amazon
Thank you geoff but
Cig. lighter is dead(the fuse is ok). I did a check and could not find a problem w/the lighter. I will tackle that lighter in the Spring.
Question still is, can I connect it to the recommended jumper ports?
Thank you geoff but
If the lighter socket doesnt work, dont take the chance of connecting via the jumper ports. I would think its best to connect directly to the battery.
Thank you geoff but
I have mine hooked up to the battery. I bought an Interstate maintainer and it has cables that hook directly to the battery and then a plug-in for the charger. Your lighter socket may just need the prongs bent in.
I'll give the cig lite a try.
Hi. So the cigarette lighter is a good place for the battery tender? i mean, if i close all the doors and lock the car, the cigarette lighter will still be connected to the battery do the tender can charge it?
Yes ninsei, the cigarette lighter is the spot used by OEM battery maintainer, with the doors locked (remote control)
I had the cigarette lighter replaced under warranty. Maybe
a new one will solve your problem.
Paul
A new cigarette lighter socket only costs about $10 or so from board sponsor Sunset. It's a relatively easy DIY
Would it be ok to keep the car covered with the battery maintainer hooked up? I know batteries give off gas when being charged. I'll be leaving my car unattended for 3 weeks in winter weather and am considering getting a tender.
The OEM style batteries have a gas vent line that runs out beneath the car, so covering the car is not an issue..................
