One beep means you have one or more alarm zones open
1 hour ago, hi8ha said:
Hi all. Long time no post.
As the title of the post sates "One beep means you have one or more alarm zones open". Where are the alarm zones located?
Thnaks
Front trunk, rear engine cover, doors, center console, interior sensor.
  • Like 2
My fuel filler door doesnt lock and I have 1 beep after locking. The little rod just stays fully extended all the time, I can even open the fuel cover when the car is locked. Anyone know whats goin on?
Sent from my iPhone using Tapatalk
I'm presuming your car is beeping once? Do you have an aftermarket stereo?
In the meantime, until you get it figured out you can lock the vehicle and immediately unlock it. In 45 seconds it will auto lock and the alarm won't go off on you.
1 hour ago, hardtailer said:
Probably addressed to Estii but I'll answer nonetheless.
Yes I have an aftermarket radio. What is the interaction between stock radio and alarm that no longer works with an aftermarket system?
The car’ s dash has a radio theft alarm circuit built into where the radio sits; left unconnected it triggered the alarm to beep.
Tape...find the ground wire and wrap some tape around the connector.  That means it is not connected to anything.  Originally the brown ground wire was connected to the radio chassis.  Now what you want to do is disconnect the ground wire and wrap some tape around the connector so it is not touching anything.
  • Thanks 1
