  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Also searching for the a lost radio code. Any help would be greatly appreciated. In fact, I am not even sure how to post this question. Thanks
ser 1 Y5047127
Becker 1
Type 4462
24/99
Cd cdp2081
Try 9373
or
9371
Thank you very much. I will give it a try later today. :rolleyes:
ser 1 Y5047127
Becker 1
Type 4462
24/99
Cd cdp2081
Try 9373
or
9371
Tried it. Unfortunately, the codes did not work and then shifted into wait mode. Any other suggestions? The local dealer/crook demands that I set an appointment late next and pay an unspecificied amount - all because of a dead battery. Thanks in advance.
ser 1 Y5047127
Becker 1
Type 4462
24/99
Cd cdp2081
Try 9373
or
9371
I needed your help. Went to the dealer and was able to obtain the code. Code provided from dealer 8368. Tried 3 times and did not worked. Still got "CODE ERR".
CR-210
R 2095
Serial Number S500150
Many thanks,
Sean
CR-210
R 2095
Many thanks,
Sean
Hmm... my program says 8368 also.
Is that the code that is displayed?
First of all thanks for you effort helping people.
I would like to have a code of my radio car, yesterday i put off the battery and now i'm without music:
Posche boxster 2.7
CDR-22
type 4467
serial y5023097
Roberto
Posche boxster 2.7
CDR-22
type 4467
serial y5023097
Roberto
Try 0206
or
0204
CR-210
R 2095
Many thanks,
Sean
Yes. The serial number was obtained utilizing your instruction. I just entered 8368 once and then push the signal seeker. Is this the correct way?
Sean
I'm going to be replacing a MAF Sensor on my 2000 Boxster 2.7 next weekend, and from other posts it appears that I might need to disconnect the battery and lose my radio code in the process. Please help me with the code if and when that happens.
The radio is a CDR-220 Becker 1 Type 4462 Serial # X5035823 24/99
Thanks a million for helping with this. I really appreciate it. - Jeff
Loren
This spring's start up brought up the dreaded CODE which didn't come w/the 2000 Boxster I got two years ago.
Hope you help me.
thanks
Becker 1
type 4462
seri# Y5041503
Try 8922
or
8920
Thanks Loren, 8924 was the magic number.
Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
hi all i need to get a navigation code have the pcm code but i believe i need the nav code only not sure how to access it since it doesnt illuminate on the screen it asks for the pcm code which i put in but rejects it and after a few tries it make sme wait a hour!! thanks
Becker 1
type 4462
# Y5038582
24/99
Hi Loren,
Just put in a new duralast battery DL-48 in my '99 C4. Of course I now have to put in the radio code which I don't have :(
The head unit is:
CDR220
Type: 4462
serial #: X5020239
Thank you,
Eric
Hi Loren,
The head unit is:
CDR220
Type: 4462
serial #: X5020239
Thank you,
Eric
Try 2664
or
2662
CR-210
R 2095
Many thanks,
Sean
Sean
My mistake. Just read the serial number again and I erronuously missing a 0.
The serial number should be S 5000 150. No wonder the previous provided code 8368 did not worked.
May I have the code for S 5000 150.
Many thanks,
Sean
Hello. I disconnected my radio (was swapping to an upgrade radio) and that newer radio didn't work so going back to my old one...the radio code written in the manual does not work.
This radio is:
Becker CDR-210
Ser # 5017744
Model # BE2282
Boxster Tiptronic - Silver/Red 1998
Can you help me with a code that will work?
Thanks.
This radio is:
Becker CDR-210
Ser # 5017744
Model # BE2282
Thanks.
Try 4615
or
4613
Hi
I have a 1998 2.5 Boxster and my radio is asking for the code, and i cannot locate the code card.
Type is 4367
Serial Number is W5007081
Can someone please help???
Thanx B)
Tim
Hi
Type is 4367
Thanx B)
Tim
Try 542`
or
5419
Hi, I am looking for a radio code for my 1999.
Becker 1
CDR 220
Type 4462
24/99
Ser # 15075468
Thank You very much...
Larry C
