  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Have Boxster 2000 S, need code for:
Becker
4462
48/98
X 5025946
thanks for info in FAQ - turns out I was given the wrong serial # info from the prior owner. The TP button confirmed the # given was wrong.
Thanks for your help!
Try 7363
or
7361
Becker
4462
48/98
X 5025946
Try 7363
or
7361
tried 7361, 7363 and 7365, a no go.... have reset and will attempt 7359 and 7377 using the 2 digit recommendation - any other suggestions?
Becker
4462
48/98
X 5025946
Try 7363
or
7361
Did you read the FAQ?
Becker
4462
48/98
X 5025946
Try 7363
or
7361
looks like I'm in the 5% club... thanks for the attempt.
$25 donation to Renn Tech
8.99 british #'s! now clue how much that really is......
Having tunes again.... Priceless!
The # from Renn Tech was one digit off... started with 7363, turns out it was 7364...I have the CDR220 model, so if it doesn't work with the two digit separation, try one up.
:clapping:
Hey guys - you're doing a great service! Just fixed my horn from beeping over bumps - and well.. you know the rest..
Thanks upfront for any help you can provide.
Here's my serial #
4462
48/98
CDR-220
X5016433
I'm in need of my radio code. I have 2002 boxster with CR-220 Becker 1, 4362, serial # 25006121. Do you know what the
24/99 means that is displayed after the serial #. Just curious. Thanks in advance!
Hi nice people at renntech could i kindly get a radio code for my becker cdr 22 radio .Model number BE 4467.SERIAL NUMBER Y5024733. Thanks.Porsche boxster 3.2S ,on a 2000 year registration based in uk RHD ,mettallic green paint thanks again .
Edited by vroom
Looks like lots of folks in this same situation.
Just picked up a 2002 Boxster, (Toyota) dealer installed a new battery, no code in any of the manuals.
Appreciate the help in advance.
CDR220
4462
s/n 15075446
Thanks for the help guys.
CDR23
Model #: BE6612
Serial #: 45059078
date: 04/04
2004 C4S
From the FAQ -
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24)."
Hi this is a personal messagefor loren , thanks a lot forthe lock codes for radio on my porsche boxster you saved me a bundle in porsche dealerhip charges, the answering service was fantastic and very thorough.Bravo renntech shall be visiting more often. :renntech:
Hi I have a 2000 Boxster S.. Battery was replaced and the security codes were lost (well, more like forgotten and lost) :(..
Help with the codes will be much appreciated!!
CDR-220
Type 4462
SER X5031576
Thx,
Mike
