I tried 9379 and 9377, but it is still locked. Any other suggested codes. Thank you so much for responding.
Did you read the FAQ? I think not.
I don't understand, what am I missing?
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Oh, I see
I have 2002 911 Turbo, CDR 220, type 4462, Serial 250 151 15 (there may be an "I" in front of number?).
thanks, Bill
ps. I disconnected battery to change ignition switch, used the $34 Audi part and the directions given on this site, went well - thanks.
Try 9657
or
9655
I have tried both of them twice and they did not work. I have gone through the 60 minute WAIT twice. It now comes up as code.
Another combination? Thanks, Bill
You can verify the serial number using the technique in the FAQ.
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
thanks, Bill
Try 9657
or
9655
All is answered in the FAQ (hint hint)
Hi Loren! Basically I'm in the same boat as most people; worked a bit with the battery, had to unplug the radio from the power and now I'm stuck with no radio since I misplaced the code.
Info:
2000 Porsche Carrera 4
CR-220
Type 4362
Ser. X5018488
47/98
Any reply would be greatly appreciated!!!
EDIT: It is a Becker 1 radio.
Edited by ahaitsmike
Info:
CR-220
Type 4362
Ser. X5018488
47/98
Try 7728
or
7726
Info:
CR-220
Type 4362
Ser. X5018488
47/98
Try 7728
or
7726
Hmm... tried 7728, 7726 and 7724, but nothing so far.
I'll keep trying multiples of two until I get it. I'll post up what the code is once i get it.
Thanks Loren!!
Hi, Loren. I'm going to install the pnp rear speakers and i'm reasy to go just need one more thing, the radio code: CDR220 Becker "1" Type:4462 Serial # X5038201 cd: cdp2081. 2000 Box "S" Thanks, Scott Stieber
Hi Loren, just picked up a CDR-220 for my 2002 C4 to replace the tape player unit. the Serial number on the side of the unit is 15088362. Can you help with the code please?
Rex
Hi Loren,
I'm in the same boat, car's been off the road over winter and radio's locked. Details:
Becker CDR-21
S/N: V5010128
Thanks for your patience.
Ravi :help:
thanks, Bill
Try 9657
or
9655
ok, thank you, 9659 did work.
p.s. the computation of the code number could be dependent on how each computer system treats round-off and thus a number differing by two may be the result in another system.
Hi Loren:
I just came upon this site after calling dealers for the past 3 days on my radio code! I bought a 2000 Boxster S from a private seller and never got the radio code. Alas, my battery needed to be changed, and so now I can't get the radio code! Here's the info - any help is appreciated...
Becker 1
Type: 4362
Serial: X5018874
47/98
Thank you again!
-Priscilla
Hi Loren:
Becker 1
Type: 4362
Serial: X5018874
47/98
Thank you again!
-Priscilla
Try 9553
or 9551
Rex
Loren I got the radio hooked up and verifited the S/N is 15088362 model number 4462.
Rex
