Hi. I'm in a similar boat. I had to replace my
6-spd. transmission, and am now locked out of my radio
and need the code, which I lack.
'99 996 310 Carrerra Cab.
Radio Model CR-220
Becker
Serial No. CDC-3 W1025884
Any ideas?
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi. Check that. In just going the actual radio
itself and holding down the TP button, I have the following
new data, which doesn't match the Becker id card that
came w/ the car. Odd.
Anyway, here it is:
Model CR 220
Type 4362
Serial No. W5002795
Its a 1999 Carrerra Cab.
Thanks.
Anyway, here it is:
Model CR 220
Type 4362
Serial No. W5002795
Thanks.
Not odd - many radios were replaced for 'peeling buttons' early on.
Mine was the same - sometimes they forgot to give the customer the new card and sometimes the owner lost it.
Try 2637
or 2635
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Anyway, here it is:
Model CR 220
Type 4362
Serial No. W5002795
Thanks.
Try 2637
or 2635
Hi. Thanks for the quick reply.
I just tried them both, and unfortunately, neither one worked. I also
tried 2633, and it didn't work either.
So, since I tried 3 to no avail, I'm into the
1-hr. 'WAIT' period.
Any other suggestions?
BTW, my buttons do "peel", and have for quite some time.
Hi, it worked! Thank you soo much for the quick reply!
cheers
Simon
Hi all, Just bought my first 911 a month ago, and now is the time to put back the stock radio! I can't find the code so here are my infos. Thanks!
Typ: CDR 220
Model No.: BE 6625
Serial No.: 15007359
12 volt EC: 102
996.645.126.10
I hope this is all that you need!
Regards
Simon
Also, it is for a 911 2002 carrera coupe
Try 9214
or
9212
Porsche Carrera 1999
· Model/Engine - Carrera
· Transmission type - 6 speed manual
· Interior color - black
· Country specific information - US
Becker CR-210
PR-VERS : R 3297
Serial Number : V5009047 or VS009047 (I can't tell if its a five or S)
Becker CR-210
PR-VERS : R 3297
Try 1689
or
1687
The best way to get the serial number is the electronic readout - as described in the FAQ.
thank you -- but it didn't seem to work. I just need to type the 4 digits in -- and it will auto start nothing after
that right? It just jumps back to the first digit blinking.
Used codes
8867
8865
tried
8869
8863
Model CR-210
WS0 12008
R3297
I have checked the S/N several times -- I have not looked at it physically by pulling the radio
thoughts?
mike
210 == the one with the cassette
R3297
WS0 12008
thanks,
mike
Try 8867
or
8865
The serial number that is displayed using the process in the FAQ is the correct serial number.
As the FAQ says - try one number difference.
Ok tried it again -- the S/N is definitely WS0 - 12008
Does the Radio have to talk to the DME through the body harness to qualify the code?
The reason I ask is that this car had its engine replaced (due to an IMS failure)
and is a 99 car with a 97 engine (and a 97 Engine Wiring Harness).
I had to rewire the engine wire harness to connect the Tank Pressure Sensor to the DME since
the 97 had a different pin out.
Could I be dealing with a similar issue?
thanks,
Mike
thanks,
Mike
No the radio does not talk to the DME on pre-MOST cars (MY2003).
Sorry, in a small percentage of cases my code finder does not work. You can try to get a dealer to get it for you free or pay Becker for the correct code.
We;; don't I feel stupid -- I thought as soon as you entered the code it would work.
turns out you have to hit tuner up to "enter" the code
However Loren -- your code did not work,
but another member's code did.
thanks to all.
Mike
