  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
HI, Loren. I'm getting ready to work on the car but am hesitant to disconnect the battery as I don't have my radio code. Would you mind checking what mine would be? My CD-220 info is as follows:
type: 4362
serial number: Y5021118.
Thanks in advance!
Edited by 996.solo2
Hi Loren,
Just picked up a 1999 Boxster. The battery was disconnected while the shop did an LN Engineering IMS update, Could you please look up my radio code?
Becker CDR-220
Type 4462
Serial # X5024191
Thanks Loren,
joe
Hi Loren,
Just picked up a 1999 Boxster. The battery was disconnected while theshop did an LN Engineering IMS update, Could you please look up myradio code?
Becker CDR-220
Type 4462
Serial # X5024191
Thanks Loren,
joe
Try 4856
type: 4362
Thanks in advance!
Try 5438
Hi Loren,
Becker CDR-220
Type 4462
Serial # X5024191
Thanks Loren,
joe
Try 4856
Wow....perfect! Thanks so much.....
Hello every one
I am new to this site and looking If anybody Can provide a radio code for my 2002 Carrera:
Becker CR-220
Ser. 15005063
Type : 4362
24/99
Best regards
Hello every oneI am new to this site and looking If anybody Can provide a radio code for my 2002 Carrera:Becker CR-220Ser. 15005063Type : 436224/99Best regards
Try 9243
Try 9243
Perfect , thanks a lot
type: 4362
Thanks in advance!
Try 5438
Much appreciated, JFP. Thanks! :D
Hi Loren,
Had to replace the ignition lock and switch assemble (great DIY by the guys here - I went the instrument cluster removal route), therefore, I disconnected the battery resulting in the need to enter the radio code. I soon found out that I did not have the radio code with my manual set. So, if you would so kind, I would greatly appreciated it.
Becker CDR - 220
Type: 4462
SN: 15062306
24/99
Thank you, Rob
Hi Loren,
Becker CDR - 220
Type: 4462
SN: 15062306
24/99
Thank you, Rob
Try 6405
From the label on the side of the radio...
Typ: CDR-220
Model-No.: BE 4462
Serial-No.: X5021458
Radio lost its brains and displays **** after I replaced my battery.
Can you send me the code? Thanks!!!
Interesting... radio keys I purchased to pull my daughter's radio in the VW Beetle also work for my car! Maybe I shouldn't be surprised.
Edited by Black99c4
becker model R3297
serial# W5022246
not sure if second digit is a 5 or an S?
1999 Boxster got it 2 days ago coldest night of the winter and the battery went dead. replaced the battery all is well but no radio code. Can you help me?
Typ: CDR-220
Model-No.: BE 4462
Try 4980
becker model R3297
serial# W5022246
Try 2341
