  1. Removing the dash is at least an 8 hour job...
  2. Try 1343 or 1341
  3. Please post your question only once. http://www.renntech.org/forums/index.php?showtopic=392
  4. http://www.renntech.org/forums/index.php?showtopic=392
  5. :welcome: In one phrase - 4 wheel drive. The TT has 4WD - I suspect it will handle much better.
  6. Are you sure it is the cam cover and not the cam actuator? When you remove the cam cover the cams need to be held in place.
  7. Sorry, then you will need to contact your dealer or Becker.
  8. In US dollars the MSRP is about $44.
  9. Try 5597 or 5595
  10. Have your dealer check it out - since your car is still under warranty. That way if it is an engine problem it is documented.
  11. Item 3 is an upgraded part. The part number is: 997.803.231.00 Height adjustment
  12. It installs the same as the B&M - except is is already assembled. So, mark the cables before you remove them and put them back in the place.
  13. Beautiful car - I just worked on a TT the ssame color last weekend. Just come yo our work on cars days - we'll help you do most things.
  14. No problem Chuck - I did enjoy seeing 1.2 on the boost gauge during our test drive. Who says that a stock TT will only go to 1.0 ;)
  15. Try 9178 or 9176
  16. Item7? If so, 996.803.541.00.01C Cover (black)
  17. Try 2568 or 2566 Neither code worked. Any other suggestions. I confirmed the serial # Sorry, then you will need to contact your dealer or Becker.
  18. Did you check your Owners Manual?
  19. (All) TSBs are available here to all Contributing Members.
  20. Just an FYI - most of these "owners" books are pretty reasonably priced by Porsche. For instance most Owners Manuals are $20 or less (MSRP). And places like Sunset Imports (Porsche Parts at Dealer Cost) are even less.
  21. Remove the rear wheel and the heat shield and there they are.
  22. :welcome: You will find the headlight adjustment procedure in your Owners Manual.
  23. Read through this thread - "Wait" is explained as is what if they don't work.
  24. From the MY02 Carrera Technik Service book (available here to Contributing Members) Porsche A96/50 Tiptronic transmission manufactured by DaimlerChrysler (Mercedes). "In contrast to previous transmissions, the new Tiptronic control unit has 250 different shift maps instead of just five. The maps permit virtually step-less adaptation. "
