  1. Please remind us - exact model and year...
  2. Try 0352
  3. Try 4972
  4. Did you get your serial number using the procedure in the Lost Radio Code FAQ? If not, please do so and resubmit the correct serial number. if you did use the procedure and the code does not work then it is likely that your radio was repaired by a 3rd party (someone other than Becker Sound). If that is the case I am sorry but I can not help you.
  5. Try 4237
  6. Yes, for Porsche specific fault codes you will need Durametric or PIWIS.
  7. Did you try clearing the code and seeing if it comes back?
  8. Didn't read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC."
  9. Try 7098
  10. Hmm.. haven't seen that. Do you have a lot of corrosion? Any pictures?
  11. And look for corrosion at the socket or wiring connections.
  12. You did not read the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  13. Try 4847
  14. Yes, Porsche supports most all models indefinitely.
  15. Porsche does not use black plastic tape. Solid brown wires are usually grounds. Perhaps a third party radio installation?
  16. It been covered here also - and there is a bit more. If you want the oil pressure gauge to work then you need to run a wire from the sensor to the cluster. Not to mention the convertible top dash lights to work correctly.
  17. Try 9059
  18. Yes, replacing a fan does not require draining coolant. I doubt both fans would die at once - plus you say you can run them through Durametric. If you clear the codes and run the car (with AC on) which is the first fault code?
  19. The airbag control unit is usually right below the PCM - so check that wires were not damaged or accidentally disconnected.
