  1. I'll try and check my '99 with my PST2 tomorrow. I don't recall a setting but mine stays off when I turn it off.
  2. IMHO... The easiest way is through the center console. The factory method is down through the door sill channel - but that requires removing a good deal of the interior (and take 2-3 times longer).
  3. List price is only $17 - Sunset Imports likely has it much cheaper. I would use the Drei-Bond (brand) that Porsche uses.
  4. Can you use the minus button to make it say "oFF"? What year is your car? I can't remember anything that is "settable" with the Porsche System Tester - but I'll have to look again.
  5. Wheel Alignment Specs, For Carrera models only
  6. Potential problems are: No triggering of the actuator, active position nevertheless. – Short to ground – Actuator faulty Triggering of the actuator, no active position – Open circuit in triggering wire – Open circuit in B+ supply – Actuator faulty No active or passive position is detected – Actuator faulty Check the wiring harness and connectors - if they are ok then it is likely the actuator. Bank 2 is cylinders 4-5-6. In a Carrera that would be the right side (passenger side). The engine does not need to come out - but it is not that easy to get to if you have big hands like me.
  7. Driving straight does not mean that you don't have a broken or damaged coil springs or shocks. Could be a loose swaybar too. And, I have seen plenty of bad ball joints that drive straight (until the joint totally fails).
  8. The parts lists at Porsche's website are woefully out of date. Here is what you are looking for: MY99_Carrera_gears_and_shafts.pdf
  9. For RHD cars only: 996.551.511.04.V01 (silver finish) 996.551.512.06.V01 (silver finish) Those may not be available anymore and you may have to order: 996.551.511.08 996.551.512.08 I think these are black finish though... check with your OPC. There is also a DIY refinishing article here
  10. Yes, did you read the DIY I linked to?
  11. Refrigerant quantity -- 900 g Refrigerant -- R 134a
  12. http://www.renntech.org/forums/index.php?s...ost&p=46877
  13. The only one my 2003 Cup Car service manual calls out is 996.512.988.9A. You might check with Gert@Carnewal.com he has access to a lot more Porsche MotorSport part numbers than I do.
  14. Or... have Eric at Bumperplugs.com paint it for you.
  15. The parts are exactly the same (as are many parts for the Boxster and Carrera).
  16. Under the drivers seat is the control box for the alarm, central locking and the immobilizer. You really don't want that wet. I would remove the seat and dry and clean all of the connections. It still may corrode and cause problems - it has happened to a few here.
  17. It is replaced with a tray. The tray has a small rubber mat in the bottom. (photo courtesy Tom Morris) There is a complete DIY here.
  18. My advice is to take it to an alignment specialist and have him check the front end.
  19. I don't see one. I think they are a MotorSport part anyway (like the roll cage). You may have to contact Porsche MotorSport.
  20. It is just a foam piece covered with carpet that just pulls out (just like the 996 series) http://www.renntech.org/forums/index.php?s...dpost&p=615
  21. Thanks! :thumbup:
  22. I send you a PM...
  23. There are no gloss black PSE switches because the switch did not come out until 2002/2003 time frame - when all the switches were matte finish.
