  1. P1123 and P1125 say that your car is running to rich for the DME to compensate for. P1128 says cylinders 1-3 are running too lean for the DME to compensate for. Perhaps it's time to check vacuum lines and the charcoal canister (EVAP) purge valve. Are you sure those are the only codes? Have someone like Autozone read your codes for free and report back here.
  2. 1. A 2.5 liter 986 is non-egas (throttle cable) - a 2.7 liter 986 is egas. So the answer is no. 2. Yes, the fender shape changes to fit the turbo style headlights. So you would need to change fenders and do some wiring. The headlight mounts do not change.
  3. Have a look at the B&M Short Shifter instructions (here. They have very good instructions for removing the rear center console.
  4. IMHO two things. One - always turn the air off a couple miles from home so that the moisture that has condensed on the coils can evaporate off. Two- make sure that your drain tube from the evaporator is not plugged and the moisture flows to the ground.
  5. Sorry - they can't troubleshoot it down to one component so you have to pay for both? I would look for an independent shop...
  6. Please do a search - that has been covered many many many times here.
  7. A new master cylinder has an MSRP of $447.89. Add 1 liter of brake fluid - about $12.00 and a couple hours of labor. Seems to me like $800 would be a fair price. I would ask them exactly what are they doing for $4,800...
  8. Are you sure your rattle is not a loose front swaybar? (fairly common)
  9. I don't know - I've never read the voltage at the at the alarm horn. Tool Pants might know -- I think he's replaced a couple of them.
  10. When the system is properly armed the lights should flash twice -- no horn. A horn chirp means one or zones is open (and not armed). Common causes of an open zone are the armrest cover and the front trunk microswitch. Two flashes to arm is normal and one to disarm (at least my car has always done that and I have no alarm fault codes).
  11. The car horns are the two behind the front bumper. The alarm horn is under the front hood near the battery.
  12. Was your car one of the one that needed the 1/04 W418 W418 - Updating Software In DME Control Unit? If so, did they do that update? or 8/04 2 2470 Engine Operation and Performance Complaints or 2/05 W612 - Replacing Accelerator Pedal Module Two out three of these required a DME software update - have they done that?
  13. Mine has always read fine using the manual's instructions.
  14. CDR-23 is a MOST (fiber optic system) which your MY2000 car does not have. A CDR-23 would not even work in a MY2000.
  15. They are just a wire so if they come on and off then there is an intermittent connection or break in the wire.
  16. TSB 4/01 9415 Headlight Assembly - Moisture Accumulation/Ventilation Concern: Moisture accumulation inside the headlight assembly. Information: With a combination of weather, temperature, and humidity conditions, the headlight lens may become fogged with moisture for a short time. The headlights of the 911 Carrera (996) /911 Carrera 4 (996) have a ventilation system which uses the incoming air from between the bumper cover and the lower part of the headlight assembly to remove the moisture. The headlights are also vented through plastic pipes located in the electrical connector that extend under the vehicle. Only a short driving time is necessary to clear moisture from the headlights when the ventilation system is in "operation".
  17. No the handbrake uses the drum type shoes inside the rear hubs.
  18. But if you just bought the car - why do they not have an obligation to check it out for you. It could be that someone simple like removed something (like the phone) from the MOST fiber optic circuit and didn't re-program the car. Sorry, this does not sound right to me - a good dealer would be happy to check it out for you with the hope of winning your future business (both service and sales).
  19. Your car should still be under Porsche warranty. Take it back to the dealer and have investigate TSB (Technical Service Bulletin) 15/03 9110 PCM2 With Bose Sound System: Sporadic Sound Failure -- dated 11-24-03.
  20. You might want to check out this post before you but new buckles... http://www.renntech.org/forums/index.php?showtopic=10368
  21. CDR-32 was used for RoW cars in MY99-02. I had heard it was very close to the US/Canada CDR-220. You might try Becker in your country.
  22. Sorry, but that is BS. Try Sunset Imports (Porsche Parts at Dealer Cost) for a good price.
  23. There are two adjustments - at the wheels and at the handbrake handle itself. To adjust: 1. Remove the rear wheels. 2. Release the parking brake lever and push back the brake pads of the rear axle until the brake disc can be turned freely. 3. Undo the adjustment nuts on the turnbuckle (arrow) until the cables are without pretension. 4. With a screwdriver, adjust the adjustment fixture through a threaded wheel bolt hole until the wheel can no longer be turned. Next, turn back the adjustment fixture through 5 notches again (release approx. 3 notches until the wheel can be turned freely, then release another 2 notches). Repeat the procedure on the other wheel. 5. Pull up the parking brake lever by 2 teeth and turn the adjustment nut of the turnbuckle until both wheels can be turned manually with difficulty. 6. Release the parking brake lever and check whether both wheels can be turned freely.
  24. Are you talking about the oil seperator in the engine sump? If so, then you remove the oil pan cover - no need to remove the engine.
