JFP in PA
  1. I would remove the relay and check the wiring running to the fan, testing both wires for continuity to ground (a short). I would also consider rigging up a set of jumper wires and trying to run the fan by itself (unplugged from the harness) as jpflip is suggesting to see how the fan behaves; while nothing jumped out while checking the fan previously, it is time to see if it actually works.
  2. Jpflip has the diagram upside down for some reason (look where the maxi fuse for the air pump is in the diagram vs. your picture)............ The three red colored relays are all the same part numbers; #8 is the fan, #9 is spoiler retract, and in the bottom row #3 is spoiler extension. If you need, I can scan a photo from the manual (looks just like your photo) and post it with the relay locations.
  3. Top row, second from right is #8 (red in color), #9 (next one over to the left on top row) should be the spoiler retract relay and have the same part #.
  4. One other thing... when I'm able to get to the relays and do the swap, assuming for the moment that the fan relay is bad, should I be plugging this into the slot that I took the relay from the spoilers? In other words if this is a bad relay, won't it blow the fuse for the spoilers too? Or would I want to try by taking the relay from the spoilers..... using that for the engine purge fan while leaving its original slot empty (not sure what electrical implications that would have but prefer not to break anything else in the process while testing). Just a thought as I'm trying to think through this. Also, is the relay #8 I'm seeking on the driver's side or passenger's side once I'm able to get this carpeted segment off? I know this is an awefully verbose sequence but hopefully when I'm able to solve this it helps something else in the future that finds this thread........ Relay panel #2 is on the driver's side of the shelf area (the engine DME should be on the other side). I totally forgot about the Bose option that requires removal of the fasteners to get the parcel trim panel up to gain access to the relays, cars without the Bose are not as complicated. Remove the two fasteners under the Bose "vents" and the shelf should slide forward. I would pull the existing suspect #8 relay out completely and move the spoiler relay (#9) into the #8 slot and then reconnect the fan to test the circuit. If everything works OK (fuse does not pop) and the Durametric can run the engine compartment fan without issue, you will need another relay. At that point, you can move the relay back into #9 slot and just leave the engine fan relay out until you get a new one (the car will code for the missing relay), or leave the relay in the engine fan slot and live with out your spoiler until the new relay is available. Aren't electrical diagnostics fun? :eek:
  5. It sounds like the fan may be OK as you do not seem to be getting continuity between the housing and the wire connections. The #8 relay that controls the fan should be the same part number that is used to control the movable spoilers on these cars, so the easiest move may be to simply try to swap the relay and reconnect the fan and turn on the ignition to see if the fuse doesn't blow with the new relay in; if that is in fact what happens, it is the relay, which is much cheaper than a new fan.
  6. Before going to check the relay, check the fan connections to the fan housing for a short to ground (you should see no continuity between either wire connection and the housing).
  7. You have it set too high, turn the meter down to 200 ohms, then if you touch the two meter leads together, your meter should read either "0" or some very small value near "0". If the fan is still reading "0" that means it is an open circuit with no resistance, which is highly unlikely for an electric motor. If you get a Ohm reading on the motor circuit at the lower setting, note it and then try getting a reading between each of the fan's connections and a bear metal area on the fan housing (you are looking for a short). If you get a "0" or near "0" reading between either wire and the housing, that is a short. Neither wire should indicate continuity to the fan housing. Next try the same test on the harness that connects to the fan, check the two wires first, then each one to a chassis ground (one should be a ground, but both should not read as having continuity to ground). If both read as continuous to ground, there is a short in the harness or the relay is shorted.
  8. You are almost home, but you need to confirm it is the fan itself, and not a short in the wiring leading to the fan. With a multimeter, check the fan's circuit for continuity, resistance, and a possible short to ground (the fan housing) on either leg of the fan motor's wiring connector. If the fan motor's internal circuit shows a short to ground, it is Miller Time and you need a new fan; but if there is no short, you need to check the wiring harness going to the fan for the same type of short.
  9. Once the fuse pops, the circuit is dead all the way back to the power source. You can now check the fan motor itself for a internal short using a multimeter. That looks like the OEM fan.
  10. You need to start looking for a short in the system. Disconnect the fan harness at the fan and check for a short; you can also try jumpering the fan itself to see if it runs without issue. You may also need to check the relay and temp sensor circuits for shorts as well. This is a process of elimination to find where the problem(s) lie.
  11. OK, if you look in the lower left corner of the image I posted above, you will see the entire left trim piece of the dash(three buttons and lighter), which contains the lighter; this has to be pull off the dash panel to proceed. Tool for the job is a wooden tongue depressor (like a doctor uses) or some similar non marring device. Slide the tool under the trim piece and gently pull the trim while working the tool around its rim to extract it from the dash. It will pop right off. Once pulled off, you will see the lighter's electrical plug on the rear, just unplug it (you cannot get the old socket out without disconnecting it). Once the lighter is unplugged, you can commence removing the old one and installing the new parts.
  12. Not really, probably an actuator issue. Relatively straight forward fix: P1341 Camshaft Adjustment, Bank 1 – Below LimitPotential causes:– Short to ground– Actuator faulty– Open circuit in triggering wire– Open circuit in B+ supplyI'd check the wiring connector for corrosion or a bad wire, a common cause.
  13. Did you change the flywheel during the rebuild? And please do not double post, it is against the forum rules you agreed to when you signed up.............
  14. Either that or find a local Indy that has one.....................
  15. Possibly, best to get it scanned on a Porsche specific system (PIWIS or Durametric).
  16. Don't over think this, and don't be concerned about possibly breaking the clear bezel on the old lighter as you are going to be throwing it in the trash when you are done. The new unit's kit should include a new one. No, you do not need to disconnect the battery, but you do need to unplug the old lighter from the wiring harness before proceeding.
  17. Without a scan and the full code readout, anything would be a pure guess..................
  18. If this dealer cannot, or will not, print out what you are asking for, I think it is time to move on and look elsewhere..................
  19. I really would not go that route as it destroys flow; most use special mounts to lower the engine so it will clear the engine cover.
  20. They are different if going from a five speed to s six speed gearbox.
