JFP in PA
  1. You are in a "crapshoot" situation. Technically, the presence of ANY metal in the engine that is ferrous in nature disqualifies the car for a retrofit by LN standards as it only takes one flake to start a series of cascading failures. Some people have gotten away with doing a retrofit on a questionable engine, others have not been as fortunate.
  2. That is the problem with this method: You only know when you are finished.
  3. We see this when the sensor has come into contact with the flywheel, buggering the head of the unit. Your only choice may be to grasp it with pliers and twist back and forth until it pops free. Normally, these things just pop right out as Duncan has noted.
  4. Using the pelican method is at the least rather risky as the set screws are pushing on the IMS shaft gear, which is only a press fit and can be dislodged by this method. If that happens, the engine has to come out and apart to fix it. There are reasons that no one else even suggests this approach.
  5. As long as the copper gasket is the correct diameter and thickness, it should work fine. For future reference, the factory aluminum gaskets cost less than a buck each, and are even cheaper if you buy them by the bag.
  6. If you do a search, someone else experienced something similar and it was a problem with the tool. SIR made good on it and replaced the tool, and the second one worked fine.
  7. Not a problem; as I mentioned, we see this regularly and everyone assumes it is the end of the world when it is just a little pebble.
  8. Welcome to RennTech Check for a small stone in between the rotor and metal splash shield; we see this fairly regularly.
  9. Some Porsche models use a Siemens DME that runs on odd software, limiting what the Durametric system, and many other systems, can do with them. Models with the more conventional DME work just fine with the Durametric system. With time, hopefully workarounds will come out, but that is the nature of these cars
  10. Not easily. The way the system works, when the immobilizer sees the RFID pill in the key, it sends a signal to the DME, which then activates the fuel and ignition systems so the car will start. No signal, no DME response, and no start. As the DME is controlling the ignition timing, spark signal, and the fuel pump, you would need to jury rig multiple systems around the DME, but then you would have no control over ignition timing, idle speed control, etc., as these are all monitored and adjusted by the DME.
  11. You are between a rock and a hard place on this one. Without a functioning immobilizer, the DME will not let the car start; without a PST II or PIWIS unit, you cannot see if the two actually do match and communicate correctly. There simply is no simple work around for this as it is the way the car was designed.
  12. (1) No. If the hub bearing is bad, it would take a bit to cause uneven wear on the rotors. (2) Not necessarily. It all depends on how the rotor is rotated while in contact with the dial indicator. If the rotation does not take up any slack in the hub bearing, the rotor could appear to run true because the hub bearing is not loaded. (3) No. The hub bearing's are simply torqued to spec, which is quite a high value.
  13. We own multiple factory flywheel locking tools (for different applications) and none of them bind up or have threading issues; they all simply drop right in and the bolt easily threads in with two fingers. What year and model is the car you are working on? The SIR P253 only fits certain years. It is also a cam timing tool (used for cam allocation), not a cam holding tool (used when the cam cover is being removed), which is completely different.
  14. Welcome to Rennech.org The immobilizer is purposely designed not to be bypassed, as the DME requires a ”handshake” with it before starting. This is specifically designed this way to prevent theft. Problems with this system due to water getting to it during rain storms and due to blocked drains it a very common issue with these cars. Look at the immobilizer under the driver’s seat, if it shows signs of corrosion, or the small fuse in it is blown, you may need to either send it out for repair, or replace it. Replacing it is not a DIY proposition as it must be coded to the car with a PST II or PIWIS unit, and the unit is pricey, so hope it can either be cleaned up or repaired. Good luck.
  15. Welcome to RennTech. This is what happens when someone looks at a problem, immediately comes to a conclusion and proceeds without actually doing any diagnostics. From the beginning, the rotors should have been checked with a dial indicator for run out and trueness. If the hubs were bad, the discs would have run true, pointing the tech elsewhere. The front hubs should have also been checked at the same time, just to make sure they were not contributing to the problem. Obviously, this was not done as build up on the hubs is often a give away that something is wrong with them. Everyone seems to have overlooked the obvious on their way to the expedient. While it is not going to help your wallet, get the car looked at and fixed by someone that knows what they are doing. This car should be an absolute blast to drive, and once corrected, you will quickly forget about the cost getting to that point. Good luck.
  16. Welcome to RennTech First of all, these engines never blow head gaskets as the gaskets are multi layer steel and actually stronger than the engine castings. The most common failure points that could cause this are an oil cooler failure, or a cracked cylinder head, so you have some diagnostic work ahead. The cooler can be pulled and pressure tested, obviously the cylinder head would require digging deeper. I would start with a pressure test of the cooling system to see if it holds; if it does not, you need to start digging further. Good luck.
  17. Two different products; thread lube is used to assure even and correct torque is being applied to the bolts, anti seize prevents dissimilar metals from corroding to each other and causing thread destruction when attempting to disassemble.
  18. You need a new dealer, online list price is only $52. Give Sunset Porsche (board sponsor) a call and see what they can do for you.
  19. The tool is a factory piece, available from dealers for around $15. You can fabricate your own tool, but with the factory unit being so cheap, it makes little sense. Yes, you can use an impact gun to remove the bolts, and then throw them away as they are designed for single use only. To install the new bolts, you will need a torque wrench and a torque angle meter for the flywheel bolts. A quality thread lubricant (I prefer ARP) is essnetial, particularly for the flywheel bolts.
  20. No, it will not fit. There is a specific tool for the M96/97 engines.
  21. The cable Richard is referring to is just that, a cable that has no idea what is on either end of it. It also does not have an electronic interface in the middle of it, like the main Durametric cable does, so there is nothing to get in the way of it making a connection with the PIWIS.
  22. The only source for the service manuals is the factory, but they stopped printing them over a decade ago. You can still find the 13 volume three ring binder sets running around on the internet for reasonable prices:
  23. Where to begin.......... Yes, you should lock the flywheel when removing it, even though the crank is locked at the pulley end. The front crank locking pin is only 5/16 in diameter, and inserts into an alloy boss on the engine cases, so the torque to loosen the flywheel bolts could damage the pin or boss. Lock the flywheel end before starting. The “cam allocation” procedure to retime the cams to the engine runs some 12-14 pages in the service manual, so I would suggest you need to get access to this information before starting this project. We have often been brought cars where the owner’s thought they knew what they were doing, but really didn’t. The result of a small error in this process can have catastrophic results on the engine, so you need to completely understand the process and tooling required before even starting this process. Good luck.
