JFP in PA
  1. Ambient temperatures should have no impact on how the sensor performs.
  2. any updates on this? Tool is actually a VW item and looks like this: About $54 from Samstag Tools Thanks JFP, just purchased. Do you know if they make or sell a floor jack pad for 2011-14 cayenne ? I don't think I can use my jack at the spare tire jack point.Any other points under car where I can jack using floor jack while doing brake at a time? Also any special tools to loosen the pads before removing the caliper? obviously there is no more room to use piston spreader with new design of caliper. I don't really know about the jack pad, but "search" is always your best friend. The pads do not need an tool to loosen them, they usually just pop out.
  3. Unfortunately, no as I am away from my shop at the moment. The latch micro switch operates both windows at the same time. If only one window is moving, it is not the latch switch.
  4. First, welcome to RennTech :welcome: The one that controls the window drop is in the top latch assembly above the rear view mirror.
  5. Ddo cars still have drum brakes? I assumed they were only fitted to low spec, non performance models. Sure do, most small or inexpensive cars, and many trucks, still use rear drum brakes. And just about every car with rear discs (including most Porsches) uses an internal drum brake assembly for the emergency brake.
  6. And what is really neat about this cheap tool is that it will work on any drum brake system, regardless of manufacture.
  7. any updates on this? Tool is actually a VW item and looks like this: About $54 from Samstag Tools
  8. What you need is a cheap brake tool that makes removing or reinstalling drum brake springs a snap: Less than $10 on Amazon : http://www.amazon.com/OTC-4590-Brake-Spring-Plier/dp/B00063V40G/ref=sr_1_1?ie=UTF8&qid=1424553458&sr=8-1&keywords=drum+brake+tool
  9. The 996 does not have a clutch accumulator, which is just above the clutch slave on the turbo (black ball like device in photo):
  10. Ah! OK, that was going to be my next question, so unfortunately we have drawn a blank there. Because of the number of possible individual switches involved, it is going to be cumbersome, to say the least, to test each one manually, as you would have to tear the car apart to do so. Is there anyone else near you with a PIWS/PST II, Durametric, or Autologic system you could use to retest?
  11. Can you elaborate on your comments? I'm not exactly sure I understand what you are referring to here.
  12. While I can honestly say I have not personally encountered what you are describing, normally when a clutch in one of these cars is on its way out, the pedal effort increases, not decreases. When was the last time your brake and clutch hydraulics were flushed?
  13. Have you scanned the car with a Porsche specific tool?
  14. If they are staying on longer than Loren pointed out, one common culprit has been a bad ignition switch (electrical section), which is a simple and cheap DIY.
  15. To find out, warm the car up to the problem conditions, remove the serpentine belt, and try turning the suspect pulley by hand, looking for unusual feel or sounds.
  16. Headlight issues: HBA codes are for the High Beam Adjustment of the Litronics servo motors. You either have an electrical issue (loose connector, frayed wiring, etc.) with one or both lights, one or more weak servo motors that move the lights, or the headlight control module itself is on the way out. From the OEM manual: Fault code 1 Motor circuit, left This fault is stored in the following cases: 1. Short circuit to ground or open circuit in the circuit between control module and servomotor for HBA, left, terminals 1,2, 3, 4 2. Servomotor for HBA, left, is faulty 3. The control module is faulty Elimination: Switch off ignition - Pull plug off the control module - Pull plug off the servomotor for HBA - Check for open circuit in the supply leads to the servomotor for HBA, terminals 1, 2, 3, 4 Ohmmeter display: < 5 Ohms - Check for short to B+ in the supply leads to the servomotor for HBA Ohmmeter connected to terminals 1, 2, 3, and 4; measure resistance to ground Ohmmeter display: Infinite Ohms - Check for short circuits between the supply leads. If no fault is detected in the wires, replace the servomotor for HBA. Also check the plug on the wiring harness side and replace if necessary. Fault code 2 Motor circuit, right This fault is stored in the following cases: 1. Short circuit to ground or open circuit in the circuit between control module and servomotorfor HBA, right, terminals 5, 6, 7, 8 2. Servomotor for HBA, right, is faulty 3. The control module is faulty Elimination: - Switch off ignition - Pull plug off the control module - Pull plug off the servomotor for HBA - Check for open circuit in the supply leads to the servomotor for HBA, right, terminals 5, 6, 7, 8 Ohmmeter display: < 5 Ohms - Check for short to B+ in the supply leads to the servomotor for HBA Ohmmeter connected to terminals 5, 6, 7, and 8; measure resistance to ground Ohmmeter display: Infinite Ohms - Check for short circuits between the leads. If no fault is detected in the wires, replace the servomotor for HBA.
  17. Decidedly yes. The CPS is a simple Hall Effect type sensor that generates a very weak electrical signal when ferrous metal moves past it. If it shorts, it will throw a specific codes, but if the signal is just weak, or even non existent, the DME just thinks the engine is not turning and shuts off the fuel and ignition without a code being thrown as the DME sees nothing unusual. It is a quirk of how crank position sensors work.
  18. I would still look the CPS as when they go bad the often do not throw any codes, but will not let the car start, particularly when warm.
  19. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit. all the numbers on the box must therefore match? The part number must match exactly, the serial numbers (between the * *) are unique to each box and all are different. What you're trying to say is that finding a used identical box is impossible? No, I am not. Using your picture above: You have to find one with the exact same 3D0 909 601 D part number; the serial number (*0036 Q 002CM1T*) is does not matter as the only one with that number is the one in your photo. I apologize if I'm nagging. I'm just trying to learn as much about my box as possible. However, you can clarify your last post, I would be very grateful. it is enough that I can find a box from a Porsche Cayenne S 4,5l 2004 model with the same 3D0 909 601 D Part Number. The serial number is thus unique to each box and is only one of each? That is correct. The serial numbers are unique to each box, so they do not matter, you just want to exactly match the part number. I appoint you to my everyday hero. Thanks for your time and dedication to my problem. Greatly appreciated! with the best porsche greetings Alexander Tobiasson, Sweden Tack. ;)
  20. You should always include the year and model when asking these type of questions as the diagnostic's can differ. Several possibles: Low fuel pressure or delivery volume, possible pump or fuel line issue. Early cars also had a fuel pressure regulator on the fuel rail that could cause issues, as well as an external fuel filter that can clog. Another would be a failing crank position sensor; when they go off, the DME does not see the engine turning and shuts off the fuel pump. You are going to need to dig in and do some testing.
  21. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit. all the numbers on the box must therefore match? The part number must match exactly, the serial numbers (between the * *) are unique to each box and all are different. What you're trying to say is that finding a used identical box is impossible? No, I am not. Using your picture above: You have to find one with the exact same 3D0 909 601 D part number; the serial number (*0036 Q 002CM1T*) is does not matter as the only one with that number is the one in your photo. I apologize if I'm nagging. I'm just trying to learn as much about my box as possible. However, you can clarify your last post, I would be very grateful. it is enough that I can find a box from a Porsche Cayenne S 4,5l 2004 model with the same 3D0 909 601 D Part Number. The serial number is thus unique to each box and is only one of each? That is correct. The serial numbers are unique to each box, so they do not matter, you just want to exactly match the part number.
  22. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit. all the numbers on the box must therefore match? The part number must match exactly, the serial numbers (between the * *) are unique to each box and all are different. What you're trying to say is that finding a used identical box is impossible? No, I am not. Using your picture above: You have to find one with the exact same 3D0 909 601 D part number; the serial number (*0036 Q 002CM1T*) is does not matter as the only one with that number is the one in your photo.
  23. That terminal lug is part of the starter's solenoid unit, which may be difficult to source separately from the starter. It would be worth a search however, as the solenoid is a fraction of the price of a complete starter.
  24. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit. all the numbers on the box must therefore match? The part number must match exactly, the serial numbers (between the * *) are unique to each box and all are different.
  25. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit.
