- Paint Codes
Schnell Gelb
Contributing Members-
309 -
Last visited
Exterior Paint Colors
Classifieds
Everything posted by Schnell Gelb
Spark plug tube seal leaks
Schnell Gelb replied to Schnell Gelb's topic in 986 Series (Boxster, Boxster S)
Thank you for the details JFP. I appreciate you taking the time to share with us gems that must have been hard-won. These gems certainly do not appear in Bentley or the FSM ! Tool - I used the all-thread+ custom sized washer technique.It was not elegant. Prying on the end of the hack tool is not very controlled use of force in a rather confined space. An upgrade to the tool I used would be to insert the end of the thread through a large(42mm) socket, then attach a washer+nut. Tighten the nut to progressively extract the tube. Must be something wrong with this simple idea to modify the much discussed bolt+washer tool - or someone else would have proposed it long ago ? The new large orange seals on my new tubes had already begun to enlarge. they were no longer tight in the groove on the tube. Yes they came as part of a rebuild kit with which I have already had a similar problem (Heat Exchanger leak). The spark plug tube seal dimensions are a puzzle. On the Pelican site they give seemingly odd measurements for their Victor Reinz seals. Maybe that is their trick part? Use a smaller internal diameter but thicker seal so it fits tighter but has the same effective o.d. when stretched into place in the groove on the tube? I am not doubting their measurements - just noting they seem odd when spec'd to 2 decimal spaces in mm .Certainly not generic 'o' ring sizes Outer Spark Plug Tube O-Ring, 27.94 X 5.33 Inner Spark Plug Tube O-Ring, 25.07 X 2.62 Here is a link to their page: http://www.pelicanparts.com/catalog/SuperCat/1048/POR_1048_ELIGNT_pg1.htm#item3 For those searching for Renntech threads on this subject - I found lots in the 996 Section that also apply to the Boxster in general terms.- 19 replies
- tube sealant
- oil leaks camshaft cover
(and 1 more)
Tagged with:
I'll translate for others.JFP is being polite and gentle with his assessment of my mechanical work. I suspect that lubed or not I must have failed to seat the small,inner seal correctly. So they all must be removed and start over with new,new seals. Interesting that you can use dielectric silicone grease but not silicone(or other) sealant. I emphasize this point because there is a lot of mention of using Permatex Ultra grey or black on the Internet but with other engines that have threaded metal spark plug tubes (Toyota for example). Thanks for your kind and speedy response JFP.- 19 replies
- tube sealant
(and 1 more)
Tagged with:
EDIT: The short version is the aftermarket tubes supplied with the engine rebuild kit were under size at the inner end and out of round ! Details 12 posts below. This is a request for ideas on what mistakes I must have made replacing the spark plug tubes and seals on my 2001 S.Yes. I searched and read lots of posts. I already have both the recommended diy tools for removing the tubes.With googling I found lots of successful installations but little discussion of stupid(me) mistakes ! I fitted all new spark plug tubes and seals when I rebuilt the engine. On an engine stand this is an easy job to do perfectly .Or it should be . Some of the seals leak.Some don't . The engine has run no more than 1 hour since the rebuild was completed What did I do wrong? All the tubes are set to the same depth int the camshaft cover.None are loose.In fact they are very tight and will be difficult to remove - the 0.90" washer+long bolt tool will help.The tubes are too tight for the transom plug tool to work. The worst leak is not sufficient to get past the seals on the coil - yet. The inside of the worst tube has a thick coating of oil after no more than 1 hour running time since rebuild. I know that (silicone)sealant is not recommended but read that some people do use sealer on the seals. They use 'sensor-safe" sealant a.k.a 'Form In Place Gasket" or Hardex. Good idea? The vulnerable seal seems to be the smallest one Part # 999-707-343-41.The large ,orange seal at the outer end of the tube is part # 999-707-25-40 and seems less likely to leak ? There is no significant pressure in the crankcase . So what is forcing the oil out ? Just a poorly seated seal allowing surface tension and gravity to leak? Specifically what sealer is recommended for tube seals that won't otherwise seal? Permatex black Ultra? Drei bond? I know if sealant is applied, only a very thin coating on the seal should be used. There are cautionary comments on excessive amounts of sealer drop off into the engine. I'll pull the tubes and buy new seals but need to learn from your suggestions on how to avoid getting more leaks before I waste more parts and time. Thank you for your ideas an help. Interesting to note that this tube design was upgraded for the 2004 model.
- 19 replies
- tube sealant
(and 1 more)
Tagged with:
Suggest you buy the replacement tank from a reputable source. There have been a rash of defective coolant tanks from the cheapo sources. The consequences are a big waste of time and materials - at best. And search for the updated coolant tank cap with part number ending "04".Pelican has a good diy on this http://www.pelicanparts.com/techarticles/Boxster_Tech/33-WATER-Coolant_Tank/33-WATER-Coolant_Tank.htm Check out Mayhew clamp pliers as suggested by JFP.
O.K. if the part leaks, buy the replacement here: http://www.sunsetporscheparts.com/
How did you confirm this is the source of the vacuum leak ?What code did you get - P0300 or another ? Is the rough (?) running worse at idle ? Fuel Trims? There are several potential methods to locate and confirm the leak. Which did you use? 1. Smoke machine 2. Propane 3. Carb cleaner/starting fluid(!!!) 4. Engine ear
Won't start
Schnell Gelb replied to hi8ha's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
look here for ideas" http://986forum.com/forums/performance-technical-chat/62660-bypassing-clutch-safety-switch.html http://www.pelicanparts.com/techarticles/Boxster_Tech/93-ELEC-Pedal_Switches/93-ELEC-Pedal_Switches.htm -
Secondary Air Test Readiness monitor incomplete
Schnell Gelb replied to mesutter's topic in 986 Series (Boxster, Boxster S)
Well done for finding an obscure fault and thanks for sharing. I was a bit disappointed you did not report a successful repair of the cracked Vacuum Reservoir with JB Weld :-)- 70 replies
- secondary air injection
- emissions
(and 2 more)
Tagged with:
996 C4 engine conversion
Schnell Gelb replied to Locosaki's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
But by then you will have rebuilt the original motor and can fit that - again & again & ..... ! That may sound factitious but it is probably closer to the reality of owning one of these cars than many will concede. M96 ownership is a gamble and if you have $10K+ cash and like playing the odds it is an exciting,high stakes game. Technically it is fascinating and if you have no other life it can be absorbing, even obsessional ! I suspect many of the cheaper 996 that are for sale are what we call "flippers" - because the current owner looses their nerve for the gamble when they realize the cars value vs repair cost is so unattractive. As soon as they get it running again, they sell quickly to avoid another big expense. -
Craig, Suggest you tell us your budget,skill and equipment level and reason for wanting the larger displacement. This has been done but the difficulty depends on how you do it. If you go for any DME 7.8 engine ,you need some very sophisticated engine management manipulation skills. It is way more than just Vario-cam Plus issues. And would such modifications pass your Smog Tests? So better to stay with the DME 7.2 you have and consider enlarging the existing engine as part of your rebuild. Hartech and AutoFarm could advise you. A rebuild with simple upgrades ( if diy) is well over $7,000. If you increase displacement or need professional services it would double. Your roller C4 may be a better candidate for a 'good used' engine than a massive expense? Yemv -
Bad Connecting Rod Bearing?
Schnell Gelb replied to Harman2907's topic in 986 Series (Boxster, Boxster S)
The M96 is different.The word "usually" from the Mechanical Engineering lexicon does not apply. Look at the oil circulation path for the M96, as I suggested earlier and you will see there is short,direct route for FOM from the oil pickup straight to 5 & 6 . So debris from other wear components hits those bearings even if the car is stationary,in neutral and the engine is idling. Tracking may cause 'sump' oil to slosh around an dislodge debris from previous incidents (like a failed IMSB from thousands of miles previously). Depending on which filtration system the engine has, the debris is quickly carried to bearings regardless of oil level or g forces. Once there is debris in an M96 with a stock filter ,the most likely cure is a complete strip,clean and rebuild because that is the only way to remove all the debris. This is the mechanical engineering reality but it conflicts with people's emotional reaction to the cost and with their experience with conventional engines. So they dicker and deny. The few rational people fit a deep sump, do UOA ,drop the sump plate,fit full flow filter and take many other seemingly needless precautions. Yes this is expensive but not compared to a rebuild. Yemv and I hope it does. -
I had a similar problem. 90k miles0n mine - yours?.Perfect service history.Mine was #5.Look at the oil circulation system ,you'll see why it is 5 &6 that fail first.Thanks Jake for that ! Mine had an LN full flow filter fitted and that caught all the debris from the bearing. There was also debris(like yours) in the pan. If you have the OEM bypass filter, the FOM has probably circulated beyond the filter. If so the only option is a total tear down, meticulous multi-stage cleaning and rebuild. Used engine may be a better option unless you are a total M96 geek like Ahsai & Schnell Gelb who lavished thousands of dollars and hundreds of hours on a rebuild+upgrade. Your old engine may have value to someone who wants the intellectual challenge of a rebuild+upgrade - if it is complete and not butchered during removal. Before you decide ,do the financial research and be sure to include any gearbox repairs that may be necessary (2nd Pop-out or bearing noise). You can easily spend $12k+ on such a project w/o upgrades and it takes months. Roller ? We'll help you through the decision making but it is rather brutal. Let's hope it is just a loose spark plug ! -
I added the reply below to a similar thread we have here. I included it because it seems so many diy guides are great successes.Sometimes there are failures that can be useful to others who follow? I made my own tool from a 3" pvc (not ABS) sewer pipe cap.Some mention 4" ,so take your old RMS as a sample when rummaging at Home Depot. I drilled 4 holes in the cap ,not 2 because I tried a 2 hole system and screwed up ! Why? Impatience. I cleaned the metal surfaces with alcohol but must have failed to wipe off carefully(?) .The slippery surface allowed the new RMS to cant over - ruined ! To remove, I used a pair of woodworkers gimlets by hand *No screw+slide hammer -too brutal ! I marked the pvc cap at 13mm and cut out "Witness Windows". As a precaution glued in a piece of Sch.80(not 40) pvc pipe at the correct depth.This acts as a stop to prevent over-driving the seal. The Sch 80 has a small cut out for the roll pin. I doubt any of this was necessary ! The contraption was too deep to use the old flywheel bolts to pull the cap on to the RMS. You need 4 x M10 x 1.0 80 mm full thread bolts . I used 4 s/s washers for undertvthe bolt heads to spread the load on the pvc . So ,if you can , borrow the correct tool or follow the earlier Instructions - not mine. My system worked but is needlessly complicated.
Thanks for this useful guide. I made my own tool from a 3" pvc (not ABS) sewer pipe cap.Some mention 4" ,so take your old RMS as a sample when rummaging at Home Depot. I drilled 4 holes in the cap ,not 2 because I tried a 2 hole system and screwed up ! Why? Impatience. I cleaned the metal surfaces with alcohol but must have failed to wipe off carefully(?) .The slippery surface allowed the new RMS to cant over - ruined ! To remove, I used a pair of woodworkers gimlets by hand *No screw+slide hammer -too brutal ! I marked the pvc cap at 13mm and cut out "Witness Windows". As a precaution glued in a piece of Sch.80(not 40) pvc pipe at the correct depth.This acts as a stop to prevent over-driving the seal. The Sch 80 has a small cut out for the roll pin. I doubt any of this was necessary ! The contraption was too deep to use the old flywheel bolts to pull the cap on to the RMS. No problem ,I have a huge assortment of metric bolts. But not 4 x M10 x 1.0 , 80 mm full thread bolts . Quick order to Bolt Depot. They only sent 2 ! Wait for some more bolts. It may have been just as fast on the left coast to order threaded rod from China and cut to length. 70 mm is not quie long enough unless you start the rms by tapping.That is rather stupid because it is easy to get it canted and that is the whole point of the tool! To complete the task with 70mm shoulder bolts, you'll need 4 spacers(big nuts) for the final few millimeters because the 70mm shoulder bolts will bottom out before you reach 13mm. So ,if you can , borrow the correct tool or follow the earlier Instructions - not mine. My system worked but is needlessly complicated.
Is this ticking normal?
Schnell Gelb replied to Justin Esposito's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Justin, I have had this issue and done a complete M96 rebuild as a result. I have no idea how anyone could say your noise is definitely a lifter based on an Internet recording ! There are many other potential causes. It requires careful diagnosis.See thread below. There are many similar ones if you search for "ticking" on this and similar Forums. -
Upgraded Rear Main Seal hack
Thanks for the great explanation. -
Anyone else tried this? "The GT3 Motorsport seal (not a Porsche standard part) is the same bore size as the 996/997 seal but has two protective flanges at the rear. If fitted in reverse the inner flange forces itself to flip backwards and touch the outer flange which is already forced onto the crank with a spring. This prevents any oil from possibly leaking even if the bore is out of tolerance."
2003 Boxster Stalls When Warm Already Changed CKP
Schnell Gelb replied to vosko's topic in 986 Series (Boxster, Boxster S)
" VERY short trips with the DME unbolted and it hasn't acted up yet. " WAG - there is a fault to ground inside the DME case. When you unbolt the DME case from the structure of the car, you cut the faulty ground path. -
Hard to Start After Fueling Up
Schnell Gelb replied to Flat6speed's topic in 986 Series (Boxster, Boxster S)
#14 here ? http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=986-97-04§ion=107-10 -
Well done, and you passed ! So to fix an SAI system rediness-fault , the fix was a post-cat O2 sensor? Just wanted to close the story because in the beginning this seemed like a very obscure and difficult case.- 70 replies
- emissions
(and 2 more)
Tagged with:
