saw this warning this morning when i started my 04 CTT
what could be the possible cause?
Edited by TopGun2000
the warning disappeared after i unplugged/plugged the two relays in the fuse box next to the brake fluid reservoir :P
no idea what they are. fingers crossed...
It happened again.
Got the brake code:
P1431
Brake Booster System - Signal Implausible
(The brake system is working just fine at the same time)
Got another code in electrical system simultaneously:
Fault code 0907
Load management operation on vehicle electrical system/
DME control module
Possible causes of fault
♦ 'no display' Loads are/were switched off temporarily. The load
management operation was enabled because of undervoltage.
Also noticed that this usually happens when the car has a few back to back short trips in one day.
All these above makes me wonder if I need to get a new battery for my cayenne (80k on the clock)...
0937 fault is a garbage fault, thats probably in every Cayenne out on the road. As for your brake booster faulty warning that is a real fault and will need to be diagnosed. An old battery will cause some random faults in these cars but I've never seen it throw one of these. A few things to check before spending any money... Check the operation of the electrical vacuum pump and see if you have any vacuum leaks in the lines running to the booster.
Edited by PTEC
It happened again.
Got the brake code:
P1431
Fault code 0907
DME control module
Possible fault cause (P1431)
♦ Leaks in brake booster system
♦ Vacuum pump worn out or mechanically faulty
♦ DME control module faulty
it happened again today. :(
do i need some special tools to check the vacuum pump and hoses?
Yes, you do. You need a special tester that can build up the vacuum to -400 to -600mbar in the brakebooster and then let it stay there. After a while you will read out the values and see if it is the same vacuum.
To check if the vacuum pump is OK you will need a Porsche system test II. It will do the adaptations och se if it is OK.
Take the car to a Porsche workshop =)
I had the same problem with my '04 Turbo. It turned out to be a broken vacuum hose on the passenger side, underneath the plastic cover, next to the windshield fluid filler tube. Start the car and listen for vacuum suction noises. The Porsche dealer said its a very common problem at that location cuz of the heat from the turbo.
Also the code was still there after I replaced the hoses and when I took it to them they said when the hose broke it sucked a bunch of dirt in the vacumm pump. They blew out the pump and everything is fine now.
I really appreciated your input. I will definitely look into that. :thankyou:
I found the problem: a cracked vacuum line (on the top of the hose at the "931" mark)!!! :cheers:
Obviously there was another old leak which was fixed by the previous owner in a JB Weld way. :jump:
:renntech:
04 TT, same fault, "brake booster warning".
Same problem as TopGun2000. the hose/plastic pipe is cracked at the connection (bottom end). Most likely due to heat exposure. Wrapped electrical tape (for now), i guess 3/4" heatshrink will also do.
P/N is 7L5-611-931 G. Cleared code, seems ok.
it is under pass side engine cover (remove blue washer lid, remove torx screw at lid, loosen rubber gasket around, remove that "+" screw lock thingy, remove plastic cover, and it's right under the plastic cover.)
15 minute job total.
Thank you Renntech, thank you Durametric!
:renntech:
  • 4 months later...
Hi
Does anyone have the part number for the lower hose? Mine is split also, done a quick fix with tape, but it should be replaced.
Couldn't find any reference to the above mentioned part number in the PET.
DS
The one that is pictured above is part # 955-355-579-51 for the piece that included the check valve. from the pump to the "Y" split and to the engine and firewall" I paid $133.34 probably cheaper online tho, if u dont mind waiting.
:renntech:
The part number for the lower hose is 955-355-577-51 (thanks to Luke at Sunset). The other part number quoted by Spyrwebs is for the upper hose that number 931 is visible on the top.
I have a question: Once the hoses are replaced, does the warning displayed in the instrument panel go away or do I need the Durmetric tool?
Hi
DS
955-355-577-71
I fixed mine by cutting off the broken hose below the one-way valve down to just above the 90o bend. I used some 1/2 inch vaccum hose to slip over the remaining pipe and bend.
Then I clamped it with a hose clamp, and clamped the other end to the bottom of the one way valve and re-inserted the one-way valve into the top part of the pipe.
Total cost about $10 and 30 minutes time, plus the new hose is so thick it'll never crack again.
Error message went after two starts and a bit of a drive.
Cheers!
