Cold Air Intake------Then Cel
Hello Guys,
I recently installed a EVO V Flow intake on my 1999 996. Things were nice, the all of a sudden I get a CEL. Now, maybe there is no correlation with the intake, but I took it off anyway and put back the stock filter. Now, I also notice a more activating winding up sound coming from a ROUND part located in the left lower corner of the engine compartment.This is piece is about a 5 inch diameter with a 5/8 hose going into it. What is it and what does it do? What should I do now about the CEL? Should I disconnect the battery and clear the fault?
Harry
The noise is the secondary air pump - used for emissions. Perfectly normal for this pump to run for a couple of minutes at startup.
Yes, you can disconnect the battery to clear the fault (but you won't know the fault then) - and make sure you have your radio code.
If it runs fine with the stock setup - then you know your problem. Either the EVO install was flawed, the parts are flawed - or it just plain won't work on your car. In the last case I have seen someone try several EVO kits and none of them would work without causing a CEL. In that case EVO gave them their money back.
Thanks Loren! I just disconnected the battery for about 15 seconds, and the CEL is still on. Is there a specific time frame that battery should be disconnected for the CEL to go out? Also, did not have to reset radio which I found surprising. Light is still on. I just replaced the starter, so now I'm thinking I may have bumped off a vaccuum line. I'm getting a small eratic idle. Smooths out a bit bit with the Air Cond though. I also cleaned the throttle body while I did the starter.
Thanks a bunch,
Harry
this may not be your issue but check to see that the bottom connection on the air pump is installed & pushed all the way in- my must not have been and it came off which caused CEL--It's difficult to see with just a casual look as it's on bottom of air pump- once i read CEL code and looked at line it was obvious- connected it and CEL gone.
Is it a hose or a plug in connector?
Try replacing the stock filter box and resetting the CEL or seeing if it goes away after a few cycles. If it does, perhaps there's something in your CAI setup that is causing a leak.
Thanks!.............I did go back to the stock filter set up. I hope the CEL goes away. When you say cycles, what does that mean exactly? Does this take a long while to happen?
Drive cycles - depends on how often you start and stop the car.
The DME (per EPA rules) is making sure the problem is gone before reseting the light.
If you want it off - then use a code reader and turn it off.
BTW... if it turns on again after that - you still have fault(s).
Put K&N cold air intake on my 99 996 3.4 and no CEL. Big improvement in acceleration from about 4000rpm on up. Big difference! Money well spent in my book. The only problem is it sounds like a sports car when you floor it.
  • 2 years later...
