Help 996 shut down while driving
I had little less then 1/4 tank of gas. I down shifted from 4 to 3rd gear & it stalled. Try to start & stalls after running for second. 1 hour later try to start & same thing. Runs for second & shuts down. I thought maybe a vapor lock because gas was kind of low. I did add a little gas from my Lawnmower can. Any ideals?
I did install a cold air intake about a month ago. Could it be mass air flow sensor?
The car does not need the MAF to idle or run well below 4000 RPM. The MAF tells the DME the airflow at higher RPMs.
I would say step one is hook Durametric, or PST2, PIWIS to the car and see if there are faults.
It is not very clear about what type of 996 it is, if it is a C4, fill with approx. 20 liters of fuel, i suspect that the fuel gauge is upset by several refillings with small amounts of gas. Let the fuel gauge calibrated afterwards.
It is a C4. And I do put small amounts of fuel in. I also hear fuel pump running when I turn the key on.
Before you start ripping into the car fill the tank at least 1/2 full to rule out gauge or fuel pickup problems.
If you have disconnected the battery, or had it go flat, when there was around ~1/4 tank of fuel your gauge may not be accurate.
This is because Porsche used a saddle tank in the C4 that straddles the front dif to get enough fuel capacity. The amount of fuel in the isolated section is not directly measured. It is calculated by monitoring the fuel use/mpg from the first ~3/4 tank.
Ok. I will try the gas thing when I get home today. Thanks it's worth a try
. The more I think about what you saying. You might be right. I did disconnect the battery when I put the cai on. Can't wait to get home & put gas in.
