MAF Fault code P0102 short/open circuit
I would start by checking the voltage to the MAF sensor first.  Disconnect the wire and put the ignition key on, check voltage.  If none, check the wiring harness connections on the right side of the engine compartment.  Disconnect them and clean with electrical cleaner.
  • 2 months later...
