  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I have 1999, Boxster. Would you be able to get me the code for it. I bought the car used and never heard the radio on in it. I had to get a new battery when I got the car. Becker CDR 220, Model BE 4462, serial#X5020315. I would be very thankfull. :D
I have a 2000 Boxster and had the same problem. At first they told me they would have to remove the radio and get some numbers off the back... but, I ended up calling the local Porsche dealership (Boardwalk Porsche in Plano TX) and they walked me through it. I can't remember exactly (I should have written it down)- but I pulled over into a parking lot for about 5 minutes to follow the mechanic's instructions and then I was back on the road. Good luck!
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Try 6856
or
6854
Those two codes # did not work, if I can't get it to work then I'll just replace it. Will the radio just start working once the codes have been entered. The car is a 1999 Boxster 2.5 US, LHD 5spd Silver with dark blue interior, not sure if that helps. THANKS
Edited by rsunnyamari
Try 6856
or
6854
Yes, the radio should work if you get the right code. Please read the FAQ.
Try 6856
or
6854
Hello,
You have to enter the code then press the tune up button. Also, If Lorens code doesnt work you can also call a Porsche dealership with the vin number to the car and the serial number of the radio they will give you the correct code free of charge over the phone. Hope this helps!
Edited by nacp1
Another lost code
CDR 23
Model BE6611
SN 35018367
TY for the help
Please read the FAQ - CDR-23 does not have a code.
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24)."
I replaced my 7 yr. old battery and it's running now but my radio is asking for the code.
Can someone help me, pretty please. also need to know how to enter the code :-(
Becker 1 CDR 220
4462
SN# X5013597
48/98
CDP - 2065
:renntech:
Edited by unklekraker
