Greetings!
We have a 2000 911 Carrera 4. We'd sure appreciate an unlock code for the stereo.
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Thank you in advance for any help you can provide.
Tery
Edited by temilson
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Greetings!
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Tery
Try 0943
Greetings!
The stereo info is:
CDR-220
Model: 4462
Serial: X5036708
Tery
Try 0943
Thank you so much! It worked like a charm!
Hi Loren! New to me 2001 996 turbo with Becker CDR220. PO didn't have the radio code and I'm about to disconnect the battery.
S/N: Y5043407
Thanks in advance!
S/N: Y5043407
Thanks in advance!
Try 0608
Request code for s/n: X5018630, please.
Model of radio please?
Whoops! Sorry, thought you only needed the serial.
Becker CDR 220
Type 4462
Becker CDR 220
Type 4462
The model number tells me how many digits (4 or 5).
Try 6034
Hi Loren, I've misplaced or lost my code card and hope you can help:
CDR - 220
TYPE: 4462
SERIAL# 15076358
Thanks in advance, I really appreciate what you do.
Doug
CDR - 220
TYPE: 4462
SERIAL# 15076358
Doug
Try 2981
I have a 2002 tt with navigation, do i have to pull the radio out to get the vin number? tried all the steps but I dont think they apply to my stereo.
I am new to the site, any advice will be greatly apreciated.
Please read the Lost Radio Code FAQ here
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Sorry, I should've read FAQ first!
It says "CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
:eek:
