Hello,
I recently purchased a 1999 Boxster.
The key which came with the car has never worked remotely (I have tried changing the battery).
When I turn it in the driver's side door, it locks the driver's door with a single honk, but does not lock the passenger door. I thought the locking issue might be an issue with the passenger door locking mechanism, but the internal door lock button does lock both doors.
I've read that the honk means the car thinks that something isn't closed, but I'm not sure if this explains the passenger door not locking. One thing to mention is that the indicator light on the lock button inside the car continuously stays on once I've turned the key in the door, but I'm not sure if this is normal behaviour.
Please, if anyone has heard of this issue, I would be greatly appreciative. Right now my car isn't too safe!
If you get a honk it means you have at least one zone open or one (or more) fault codes.
You will need a Porsche compatible scanner to get the fault code and report it here. It should narrow down exactly where the problem(s) are.
Hi Loren,
Sorry for the delay in replying. I got a scanner and it's reporting that there are no fault codes. I presume it is Porsche compatible as I'm able to read all the other information it can show.
If that's right, then the honk must mean that there is a zone open, as you said. I guess it is most likely detecting that the passenger door is open, and that's why it isn't locking. Maybe that logic is flawed. I'm not sure why I'd be able to lock it using the button on the dash, just not my key.
I read that it's common for the central console to be open and causing this issue, but I've made sure to lock that.
 You need a Porsche specific scan tool to see the faults, something like the Durametric system or a PIWIS system, no other scan tools will be able to see the faults.
