  1. I am in Morgan Hill (just South of San Jose). If you want I can hook up my PST2 and we can test both fans and both speeds. PM me if you want to do this.
  2. The radiator fan fuses are C8 and C10. I doubt they would run at all with the fuse blown. I wonder if you have a bad fan ballast? Where are you located?
  3. For the oil problem - have they run a compression test on each cylinder? 1. Likely a badly worn synchro - I would guess a rebuilt/replacement transmission is the only fix. 2. Have a tech check your car for a voltage drain. 4 years is good battery life for any battery (regardless of cost).
  4. The kit including the electrical harness, screws, clips etc. is: 996.512.901.02.G2X
  5. Yes, you can plot those with the Car Code software. These images I posted ( a year ago) actually came from the Porsche OBD II service manaual.
  6. Porsche has had the issue with the crimped hose at least a couple of times. Another possibility is a blow fuse that will shut the vent off. A third possibility is a bad canister/purge valve circuit (that again shuts the vent off - usually you get a CEL with this.
  7. No, and I am pretty sure a dealer can not do that with their PST2 or PIWIS tester.
  8. They start delivering cars in December (in the US) so it could be any day now. As soon as we have it will be posted here.
  9. Here is a pic from one of our Moderators. The heat shield is the foil looking stuff around the muffler. You do not need to remove the bumper or jack the car up. Just wait until it is cool or use protective gloves to isolate the rattle. In a few cases there have been broken welds inside the muffler too. (pic courtesy of Orient express)
  10. Did you check the heat shields around the mufflers? That is fairly common.
  11. Porsche publishes a service information book every year that details the changes for the techs and dealers (fairly technical). For the MY2002 TT the book was 17 pages. Contributing Members here can view the book online.
  12. If they are factory Litronics then they have self-leveling - if they were added later they do not. The wiring is not present and would be a big pain to add, plus the sensors (front and rear), and the control unit.
  13. These have both been been covered here many times - please try using the Search feature. You will need the Durametric Software (about $250) or a shop with a PST2 or PIWIS tester to reset the airbag light. What is more important is to read the airbag fault code(s) to see what caused it to come on in the first place.
  14. No.
  15. No, they are the same (at least to my ears).
  16. Disconnect the driveshaft at wheel end only. You will also need to remove the lower balljoint. I would drive it around some before alignment so the springs are settled.
  17. 996.552.233.06.A03 Trim for switches (black) -- MSRP $59.03 (in USD as of October 2006)
  18. Strange dealer - Porsche says every 20,000 miles.
  19. Most of the MY07 Order Guides have been updated today. That also includes the MY06 Cayenne S Titanium edition that will be sold in 2007.
  20. There was a glitch today with this server (and many others) with time server synchronization. The problem has been corrected but you will see a few posts that will look like they they were written in the future (i.e. 9:00 PM instead of 9:00 AM). This will also cause your New Posts and Mark Forum as Read not to work until the actually time "catches up" with the wrong posting times. So, everything should be working properly again in about 12 hours. Sorry, for the problem but this time server glitch affected thousands if not millions of servers.
  21. These are the brackets for a 997 with comfort seats. If I misunderstood and he has sport seats then the numbers are different.
  22. If it can show actual valves (from the DME) then you can compare - if not the Durametric software is only about $250 (vs. $3600 for a used PST2).
  23. Depends on the scanner... the Durametric Software will.
  24. Do we know that the climate control measures that temperature at the same place as the DME? Perhaps the climate control reads the temperature at the heater core inlet? and the DME reads it at the engine? I may try to hook up my PST2 to my car and see what the DME temp says compared to the climate control.
  25. Yes, the sway bars are the same for X74 and M030.
