  1. Perhaps you mean Grey/Pink from I (blue connector) to pin 13. That would be the Speedometer A sensor wire. Here is the brake sensor wiring...
  2. Perhaps you can tell us what you are working on - there are separate wiring diagrams for each model year and then up to 40 pages of diagrams for each model year.
  3. Try 2637
  4. Try 13211
  5. No relay - it runs off the Onboard Computer Network.
  6. READ and follow the procedure in the Lost Radio Code FAQ. This topic is closed.
  7. Try 4709
  8. Try 7387
  9. Try 51131
  10. Thyen perhaps part of your display is out.
  11. Entering the antitheft CODE This radio renders itself inoperative in the case of theft. If the radio or car battery is disconnected, the radio automatically disables itself. Once the radio is reinstalled or the battery is reconnected, the word "CODE", with a flashing letter "C", and the digits 1-0 appear in the display. Prior to use, the correct code must be entered via the multifunction keys. Example: CODE 1530 (Preassigned to each radio and supplied to the owner on the PORSCHE RADIO CODE CARD) is entered by pressing the multifunction keys in sequence. After the first digit is entered, the word "CODE" disappears and the number is displayed followed by three dashes. As digits are entered, the next line in sequence flashes. When all four numbers have been entered, the first digit flashes. At this time you can overwrite the code as often as necessary. To correct any error, you must enter the complete code. Once the correct code is displayed, enter by pushing the signal seek switch. If you have entered an incorrect code, the word "CODE" reappears in the display. The system allows two more attempts for a total of three. After three incorrect attempts, "WAIT" is displayed. A ten-minute time interval must lapse before you can attempt the coding process. You have three more chances to enter the proper code at this time. After nine attempts at code entry and three waiting periods of ten minutes each, the radio will "WAIT" for sixty minutes. After sixty minutes, you will have three more attempts at code entry. Should you fail at this point, "WAIT" will appear, and sixty minutes must pass before you can make another attempt. Attention: The radio must be on during the waiting period.
  12. Try 0190
  13. Fuse 16 in the left fuse support. In many cases, it is not the fuse but a bad horn (or horns). The factory horns are not very good.
  14. Try 7087
  15. Try 0401
  16. Try 0765
  17. Try 8741
  18. Try 8217
  19. Try 2103 This is the third time I have given you a radio code - perhaps you would consider a donation to this site.
