  1. Same thing - added weight for 4WD vs 2WD.
  2. Try 6879
  3. You need to READ the Lost Radio Code FAQ.
  4. How old is your battery? Have you had it load tested?
  5. Try 9605
  6. Try 3048
  7. Try 4289
  8. I think you mean the Durametric scan software. Yes, you need to clear the error (in most cases) then retest to make sure. I am removing your duplicate post with the same question -- please re-read the board Guidelines/Rules that you agreed to when you registered here. "Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
  9. Try 1296
  10. Try 2107
  11. Try 8724
  12. Did you put a code tester on it? If you post the codes here we can help,
  13. Try 9323
  14. How old is your main battery? Cayennes seem to have a number of strange electrical problems when the main battery is weak or failing. If your battery is 4 years old or older I would start by replacing it.
  15. Try 0478
  16. The interior colors available for MY2011 Carrera 2S were: Black Stone Grey Sand Beige Sea Blue Terracotta Cocoa Darkgrey natural Brown natural Carrera Red Expresso If you PM me your VIN I might be able to find out in a parts lookup.
  17. I agree removing the inside door panel is the only way to get at the broken latch mechanism.
  18. Please be more specific - most folks use "CS' For Cayenne S. Is this a Cayenne or a 997-2?
  19. Have a look at this... http://www.renntech.org/forums/topic/2275-remove-tiptronic-shift-knob/?p=10388
  20. Try 0191
  21. And the model number on the front of your radio is? Try 8751
  22. And the model number on the front of your radio is?
  23. All of this is explained in your Owners Manual (if you have one). (click to enlarge)
  24. Try 5146
