JFP in PA
  1. Possibly a shifter cable wear/misalignment issue. If the car has the factory shifter, you can get a cheap (`$10) alignment tool from Porsche that holds the shifter in the correct position while you adjust the cables to match: If that does not do it, you are into checking the gear box internals
  2. First thing I would check is to see if the gearbox has the correct factory lube in it. If that is unknown, I would drain it and refill it with the factory stuff You would be surprised how many shifting issues are solved by doing this.
  3. I just did a quick check of the PET, and Porsche agrees with the dimensions Pelican lists, but Porsche also lists two different inner and outer O-rings depending upon the year and model of the engine (3.2 vs. 2.7L), which usually means there is something different. Pelican is well known for listing parts that almost fit, either because they are aftermarket or just listed incorrectly, which is why over the years we have purchased very little from them. We get our plug tube O-rings direct from Porsche, and they fit correctly.
  4. Silicone grease is extremely slippery and allows O-ring seals to slip into their groove recesses without getting pinched or cut in the process. Silicone sealant on the other hand is very tacky, transfers to whatever it touches, and then dries to form a bond to what ever it touched, so if you get an O-ring pinched or out of position in its mating grooves (which is actually easier to do when using the tacky sealant) it will not only leak, but is now adhered to the components. So when it does leak, you now have a bigger headache trying to clean up the mating surfaces before putting new replacement parts in. Often, this entails removing the cam covers, which is not a lot of fun with the engine still in the car. The small inner O-ring on the plug tube (the black one in the photo) has to pop into a machined recess in the cylinder head without getting cut or coming out of the groove on the tube in order to form an oil tight seal, so lubrication is the key. The larger O-ring is less prone to pop out of place, but also benefits from lubrication as well. The entire process is to install the rings onto the tube dry, then apply a thin coating of silicone grease to the outside of the O-rings. The tube will go right into place with minimal effort and the rings will form an oil tight seal. And then it is Miller time....................... And before anyone asks, the lower tool is the factory item for extracting the tubes.
  5. I actually know Logray, but again, such sealant use on the flange perimeter and bolts is both unnecessary and can actually be detrimental and end up causing leaks. Green Loctite on the center bolt is correct as it is a wicking sealant to prevent any potential leak if the internal o-ring seal on the center bolt fails. We have installed a lot of IMS retrofits over the last nine years, and we never used sealant, and have not had any come back with leaks. Anyone that has taken Jake Raby's engine rebuild school classes will tell you the same thing, and Jake developed the process, tooling, and actual replacement bearings in conjunction with LN Engineering.
  6. The valve is a Schrader type, much like the one in a tire stem. They are not made from the same materials however, so you need one for AC use. To remove it, you need to recover all the gas out of the system using an appropriate system; then the valve can be removed and replaced. From there it is a simple evacuate and test for leaks and a recharge with the correct amount of gas.
  7. OK, you need to rotate the engine by hand using a wrench, only turning the pulley clockwise, never counter clockwise, until the pulley hole lines up with the pin boss. Once the pulley bolt is out, you can pull the pin and simply wiggle the pulley to pull it out. Then reinstall the bolt, turn the engine if it has moved to orient the pin opening, and reinstert the pin, then complete the torque plus rotation process. Then it is Miller time.......... And just a by-the-by in passing, you will not find much of Porsche's original literature posted online, they have gotten draconian about protecting their copyrights and go after any one that does post their stuff.
  8. We use a dielectric silicone grease on plug tube seals. Some simply use engine oil, but in any case you need to make sure they are lubricated as they can be pretty easy to dislodge when installing the tubes. You should never use any type of sealant on these O-rings.
  9. It is not uncommon for Durametric to take some time to respond, they are often working on multiple "bugs" at any given time.
  10. No idea, but I will tell you whoever did this does not know what they are doing. The IMS flange uses outside seals to seal to the cases and should never have sealant applied to them as the sealant will actually cause a leak, not stop it. Secondly, the three peripheral bolts are micro encapsulated bolts, which again do not require any sealant for the same reason.
  11. The crank pulley is held with a pin inserted into the engine case. Its diameter is about 5/16 of in inch, so you can use any suitable rod or smooth bolt to do the job.
  12. No, it is not particularly difficult, you will need an appropriate sized wrench that can get to it (space is restricted), but the sensors unplugs from the harness and unscrews. You will need to torque the new one in to the correct spec however.
  13. Crank pulley is 37 ft.lbs. + 90 degrees.
  14. I would scan the car with a Porsche specific tool like the PIWIS or Durametric system, looking for pending codes.
  15. One or more of your locking systems micro switches is acting up and may need to be replaced. The alarm beep is telling you that the car is not locked.
  16. Tightening torque: 25 Nm (19 ft lb)
  17. Only with some difficulty and expense. You would need to add the PSM control system, which uses the ABS network, and reprogram the DME to recognize it. It would be a bit of work, and the cost would probably not be recovered at resale.
  18. You do not have to disconnect the battery when working on the O2 sensors. Which bolts do you need the torque specs for?
  19. What scan tool was used to obtain this data/
  20. If you scan the car with a Porsche diagnostic system, you will be able to read the last ten alarm faults, which should point you to what is causing the beep/red light. We have several customers with some very serious aftermarket audio/video equipment in their cars, and none of them have the issue you outlined.
  21. From the combination of the odor you describe and the sound, you have a cat on the way out.
  22. Welcome to RennTech The problems with Boxster coolant tanks is well known and has be covered several times previously, so "search" is your friend on this topic. If we had a car with a suspected tank leak, our first step would be to run a static pressure test, both to see if the system is loosing pressure, and from where. If the tank has gone bad, the replacement is fairly straight forward, but is going to take some time (couple of hours) due to the complexity of how it is connected to the system and it's location. You will also need a set of cable hose clamp pliers as some of the factory clamps are in very restricted positions.
  23. Actually, if you check LN's website, they have upped the suggested replacements to 75K miles for most of their ceramic hybrids. Both Charles and Jake have consistently taken a conservative view on the life expectancy for the ceramic hybrid IMS bearings, but as more data has been collected over time (9 years of successful field usage), they have expanded the unit's useful life.
