JFP in PA
  1. Some “mayonnaise” like build up on the oil cap is normal and not necessarily a sign of anything. Before giving the car a Viking funeral, do some diagnostics first, such as pressure test the cooling system and leak down the cylinders. You could just have a cracked cylinder head, which is not uncommon and a relatively easy fix. You need more data before making any decisions.
  2. I’ve never done one that way, so I cannot comment.
  3. The fourth stalk can be added.
  4. Simple: The cooling system operates at 18 PSIG; the oil system runs 50-70 PSIG; which way do you thing the fluid would move?
  5. The specialty hose is nowhere near that expensive, but not commonly found in auto parts stores. It uses special barbed fittings that require no clamps to hold the hose on the fittings. And no, you cannot use common auto parts hose in its place, the hose will blow off and spew gas all over your hot engine, resulting in an instant Viking funeral for your car. Either get the correct hose, or buy the entire assembly from Porsche; your car and insurance company will thank you.
  6. That is a specialty hose for use with non removable barbed fittings.
  7. I don't offhand, but board sponsor Sunset Porsche's part website will.
  8. The car actually has several different "computers" that control different functions. The DME should not impact brake light functions, but the ABS/PSM unit might. The 991 618 145 is the electronic parking brake control unit.
  9. The engine needs to be lowered down enough to gain access, or just dropped out completely. As for how to use the tool, I would search for online DIY articles, or look for a copy of the factory service manual for the car.
  10. Yes, that is the seal and the cam tool set.
  11. Cam covers with metal plug tubes do have seals at their base, but changing them requires removing the cam cover, which requires both special tooling and some knowledge of the Porsche cam timing technology.
  12. You ONLY need to activate the ABS/PSM control network if you have gotten air in it, otherwise just pressure bleed as normal.
  13. What year is the car? Later cars do not have removable plug tubes.
  14. I see a Time-Sert threaded insert in your future...….
  15. Run the cooling system pressure test; if it doesn't hold pressure, run cylinder by cylinder leak down tests to identify which hole(s) it is.
  16. The immobilizer system. You need to stop parts swapping and start basic diagnostics; start by checking the pedal switch wires to see if you have both power and ground. Then check the harness for continuity to the brake lights themselves, and the tail light grounds.
  17. Welcome to RennTech These engines use multi layer steel head gaskets that are actually stronger than the head or block castings; literally, they never fail. I would suggest having your cooling system pressure tested, you may have a failing or slipped cylinder liner.
  18. The clutch switch is for the cruise control system.
  19. It should not be twisted.
  20. Welcome to RennTech I really don't think the two are related other than by coincidence.
  21. Yes and no, cabrio is much bigger, so it would fit but very loosely.
  22. Some shops make their money with "add on's" like this. If you are using a quality full synthetic, you simply don't need additives.
