  1. Is the a CR-21 or CR22? I have no idea if this will work for your radio... Try 8469 or 8467
  2. Here is the picture that is in the parts list. There is also a "Operating Instructions Multimedia Interface" 997.044.901.74 that I assume is some sort of manual...
  3. 997.504.573.02 Left rear wheel liner (RS) 997.504.574.02 Right rear wheel liner (RS) You will also need the plastic nut 999.049.028.40 (sorry I can't remember if it is 1 or more). And, tapping screws 999.073.231.09
  4. Try 6803 or 6801
  5. Another possibility is a very erroneous reading from your MAF. Can you check your TRA, FRA, and MAF air flow readings? If not you may want to try a new MAF.
  6. P0446 (Porsche fault code 95) EVAP Canister Shutoff Valve (Function) - Below Lower Limit The task of the shutoff valve is to seal the purge air line to the EVAP canister during the fuel tank leak test (at startup). Potential causes: - Bad gas cap seal - Purge air line blocked. - Flow resistance of EVAP canister too high. More here
  7. CDR22 - is wired radio -- CDR-23 is MOST (fiber optic) based radio. Sorry, they are not interchangeable.
  8. http://www.renntech.org/forums/index.php?showtopic=19983
  9. You can only buy the two repair kits. 951.352.917.01 30 mm kit -- US MSRP $10.82 951.352.917.00 28 mm kit -- US MSRP $12.57
  10. I think you will need to change the hubs too if you put GT3 brakes on the car. Some folks that just want red calipers just buy the one for a Boxster S - they are the same caliper as the 996 -- just red.
  11. Hi, I also did not get the code card with my used Porsche and the battery went dead over winter. Next year battery maintainer! Any help would be appreciated. It is a 2000 Carrera CDR-220 Type: 4462 Ser: y5040879 24/99 Thanks. Try 0857 or 0855 Tried 0855, 0857, 0856 and 0858 none of them worked but I will cycle through them a couple of times to be sure....... lots of waiting. Thanks for the effort. 0859 worked Thanks. Hi Iam from germany...i bring a boxter from miami to Munich(Germany9 but i lost the CODE from the Radio Model CR 210 Art. R3297 SerN. V5008018 Please HELP ME......Thank you greeting from Germany...sorry my english is not sooooo good. Try 1143 or 1141
  12. The only listing I see for RoW cars is for the rear bumper cover. It is: 987.505.993.00
  13. Do a search here for the reset procedure (which involves reversing the battery for a few seconds). If that doesn't work then you likely need a new remote (check with Sunset Imports for the best price I've seen).
  14. :welcome: Search is your friend. Please give it a try. Many discussions here on swapping motors.
  15. MSRP $18.71 from your dealer if you would like to scan one for us...
  16. 97_993TT_radio.pdf
  17. http://www.renntech.org/forums/index.php?s...ost&p=20176
  18. You are lucky if the fronts don't rub now - so I would not mess with them. The rears may need a trial fit for the same reason - if they rub drop back to a 285.
  19. That is why I posted a pic ;)
  20. :welcome: Please do a search here for P1125. This has been covered many many times.
  21. VW special tool 3217
  22. Under the dash to the left of the steering wheel (all Porsche's are the same).
  23. No Idle Control Valve on egas cars. It would not hurt to clean the throttle body but that is not likely the starting problem. What did you use to check the fault codes?
  24. The sensors are just wires - that when worn through trigger the light. So, if you want to bypass them you will need a wire jumper at each wheel -- or buy new sensors and tie-wrap them away from any moving parts.
