JFP in PA
  1. The procedure's are exactly the same for both systems.
  2. A Porsche specific diagnostic tool is always the best approach as it can seen things a global OBD II system cannot. I have not idea why the car's level control it not working properly, but it also may need recalibration.
  3. I don't think it is necessarily your DME, but several of those faults look to be communications issues on the CAN bus network.
  4. Not so much the comfort level, but maybe Im not understanding the simplicity of access :huh: Can I get to the terminal and primary wire just by removing the tire and wheel well liner? If not, and you have to go through the first parts of the alternator removal process, I dont see how you could do that, hook everything up, and still have the engine run. Edit: Im sure your way is much more thorough and appropriate, so dont think this is a counter argument :cheers: I just read the instructions that came with the load tester. It says to just hook up to the battery terminals and when you rev to 12-1500rpm it will run a charging system draw to test the alternator. That method is a bit more basic and will show the voltage response, but not validate the diodes functions or provide an amperage output value. For simplicity, try their methodology and see where you are before digging in further.
  5. To fully test the system, you need access to: Both the positive and negative battery terminals (for load test device heavy cables). The terminal lug on the back of the alternator where the primary wire attaches (for checking diode ripple). The alternator primary wire itself (for an amp meter to clamp around and measure current draw). If this is outside your level of comfort, I'd suggest taking it to a shop to have it tested.
  6. Wait, so I need to tear in and get alternator access to test the alternator? Yes, you need to access the primary wire on the alternator.
  7. Does the alternator test need to be done at the alternator terminals? That sounds dicey... Clamps on the battery, but with an amp meter clamped on the positive alternator lead to read amperage draw, which shows how the unit is responding to the load on the battery. Again, many auto parts stores have this setup for free use by customers, so check you local before buying the hardware.
  8. Thanks! Can testing be done at the jumper terminals by the brake fluid? No, it has to be done at the battery terminals.
  9. This one says its good for 125 amps and I can pick it up tomorrow in store: http://www.northerntool.com/shop/tools/product_200611634_200611634 Google isnt turning up much for testing the alternator with a load tester (it is all multimeter)...how do you do it? Instructions should come with the unit, but this is the basics: http://www.delcoremy.com/MediaLibraries/DelcoRemy/DelcoRemy/Literature/Troubleshooting/Delco-Remy-Charging-Troubleshooting-Guide-8-13.pdf
  10. With my battery pushing 3 years and the battery from Advance Auto being such a good deal I just went and got it. If the air suspension works properly again after install thats probably a good sign. I did the "turn everything on" alternator load test suggested in ekstroemtjs old thread. Idling with headlights, rear defrost and A/C on, Im at 13.6v. My multimeter broke so I dont have the greatest capabilities at the moment. The fact that the live data read 9.5v the first time I tested a startup would at least suggest the battery isnt great right? If the new battery doesnt make an immediate difference (suspension) Ill get a meter and do some better testing. Could be, but I would not be swapping out anything with out testing first. The correct way to test a battery and alternator is with a load testing device, which puts extreme loading on each while also monitoring how each responds. The devices themselves are not particularly expensive, and many auto parts stores now have them available for customers to use for free. This is the one we use in the shop, very quick and accurate testing, and it cost about $75:
  11. I dont know how accurate the DME live data feed voltage is, but I had 12v at rest, 9.5V when starting the car, and 13.6-13.9 running. Voltage is slightly low, normal range is 13.5-14.5V. I would load test both the battery and alternator.
  12. I would note the codes, and clear them, then test the car again. If the same codes come back I'd start with the throttle position sensor system, which seems to be the source of many of the codes, but I would load test the battery and check the alternator voltage as well.
  13. To my knowledge, every car came with a dash equipped for cruise, regardless of if the car had the option or not. The Porsche parts list does not list a "non cruise" cluster, so yours must have it, and according to the owners manual for your car, it should be in the speedometer section, not the warning lights section (page 84 of the attached: http://www.porsche.com/all/media/pdf/Owners_Manual_Boxster_PCNA.pdf). Most likely, your car simply does not have the bulb installed. Thanks for your reply. In the Owner's Manual that came with my car it says the Boxster (2.5L engine) has the warning light on the speedometer. My car is the Boxster S (3.2L) and the manual indicates the Cruise Control Indicator Light is on the 'warning lights section'. You are partially correct, this is the "official" image of the dash that is in your car: There are two cruise indicators possible, 3A and 3B. 3A is for the base car (which is a 2.7L, not a 2.5L which was discontinued a couple years earlier), 3B is for the 3.2L S car. In any case, again, the parts listing does not show anything about "with cruise" or "without cruise" part number option; so I would still look for either a missing or non functional blub. Awesome photo. My car is 3B. Is there a possibility that the instrument cluster/warning lights & DME didn't get activated for cruise control by my mechanic? Not likely, the cruise activation is a single step process, so it should be active if the cruise is working.
  14. Do a search on removing and drying the internals of the box under the seat, some can be recovered this way. If that does not work, the car will need to be flat bedded to the shop.
  15. Not really. The new thermostat may be a bit hotter than the old one, unless you used the LN low temp unit. I would also hook the car up to a Porsche diagnostic tool and check the coolant temp with that, the dash gauges in these cars are not known for their accuracy.
  16. To my knowledge, every car came with a dash equipped for cruise, regardless of if the car had the option or not. The Porsche parts list does not list a "non cruise" cluster, so yours must have it, and according to the owners manual for your car, it should be in the speedometer section, not the warning lights section (page 84 of the attached: http://www.porsche.com/all/media/pdf/Owners_Manual_Boxster_PCNA.pdf). Most likely, your car simply does not have the bulb installed. Thanks for your reply. In the Owner's Manual that came with my car it says the Boxster (2.5L engine) has the warning light on the speedometer. My car is the Boxster S (3.2L) and the manual indicates the Cruise Control Indicator Light is on the 'warning lights section'. You are partially correct, this is the "official" image of the dash that is in your car: There are two cruise indicators possible, 3A and 3B. 3A is for the base car (which is a 2.7L, not a 2.5L which was discontinued a couple years earlier), 3B is for the 3.2L S car. In any case, again, the parts listing does not show anything about "with cruise" or "without cruise" part number option; so I would still look for either a missing or non functional blub.
  17. Such information is the copyrighted intellectual property of Porsche and cannot be published on a forum without their permission.
  18. To my knowledge, every car came with a dash equipped for cruise, regardless of if the car had the option or not. The Porsche parts list does not list a "non cruise" cluster, so yours must have it, and according to the owners manual for your car, it should be in the speedometer section, not the warning lights section (page 84 of the attached: http://www.porsche.com/all/media/pdf/Owners_Manual_Boxster_PCNA.pdf). Most likely, your car simply does not have the bulb installed.
  19. Hind sight is always 20/20. When these mounts go bad, the rubber isolator typically tears, allowing the mount to go metal to metal, which is what makes the noise.
  20. Yup, front motor mount. You symptoms are the common ones when this starts to fail. Not a bad DIY swap as well.
  21. So you are looking for the standard values you would expect from a properly running vehicle. In their most condensed form, you would find them in the specifications section of the OBD II diagnostics manual for the specific vehicle, which is difficult to find as Porsche has stopped printing them several years ago. A second source would be in the Bentley manual for the 996.
  22. For checking for leaks, would putting the Motiv Pressure Bleeder on it, and taking it to 20PSI and leaving it on over night work to check for leaks? It might, but it may also mislead you somewhat as the braking system operates at hundreds of PSIG, which the Motive system cannot duplicate.
