JFP in PA
  1. And people wonder why I dislike these aftermarket kits. Because of the energy required to run a HID headlight, the HID bulbs do not run on low-voltage DC current, so they require a power pack (ballast) with either an external or internal ignitor, which controls the current given to the bulb. Considering automobiles use a 12-volt electrical system for their lamps and the HID lighting requires over 20,000 volts to ignite the bulbs and then 85 volts to keep them running, the ballast is a necessary part of the system. Apart from turning it on it also regulates the voltage, and is an integral part of the HID system. The power-up of the bulbs happens in three phases. First comes the ignition, when a high voltage pulse is used to produce a spark which ionizes the Xenon gas, creating a tunnel of current between the Tungsten electrodes. After this comes the initial phase, when the temperature in the bulb capsule rises rapidly, the metallic salts vaporize and the resistance between the electrodes fails. Most likely what has happened is that the ballast or high voltage igniter in your kit has failed and has sent a high voltage spike backwards into your lighting harness, damaging something in the harness network. As we can only hypothesize what has happened, you are going to need to get a wiring diagram for the car and start electrical testing diagnostics to find out where the problem lies. You could have fried the alternator diode bridge, the voltage regulator, burned part of the harness itself, or even the dash light switch. Good luck.
  2. Try this: http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
  3. Not really, we have seen all sorts of things create drain. But this process will help you isolate it quickly.
  4. Disconnect the positive battery terminal and connect your multimeter between the cable and the battery while set on milliamps; after about an hour you should see 40-60 mA (normal parasitic drain from the clock, computer, radio, etc.). If you see more than 60 mA, start pulling the fuses one at a time until the drain drops back into range; that fuse circuit is the source of your problem.
  5. And the Castrol SRF is retailing at over $60 per liter here.
  6. It should not be hard for someone with a PIWIS and some DME knowledge to code the system in an hour. I'd call around and see if you can find an indy to help you with this project. I also would not write off all dealers either, a phone call would cost very little and you might catch a service manager on a good day.
  7. That depends upon the dealer. Some time back, Porsche NA instituted a program with their dealer network concerning activation of options that were not on the car when delivered, which requires the dealer to charge the owner an amount equivalent to what the option would have cost. Some dealers have chosen to ignore this, particularly for a good repeat customer; others not so much. You might be better off looking for and independent with a PIWIS.
  8. Most owners (and shops) tend to stick with the "super" DOT 4 fluids such at the ATE products, which demonstrate very high boiling points, as well as very good all around performance. Many of the DOT 5 fluids are silicone based for a somewhat higher wet boiling point, but have also demonstrated higher compressibility than other types which has made them suspect for any high performance applications. DOT 5.1 was developed to overcome that shortcoming by switching from silicone to a borate ester/glycol ether or polyethylene glycol while retaining the higher boiling point of the silicone based products, but also tend to be on the expensive side, with a 1/2 liter container approach the cost of a liter of DOT 4. But by far, the largest selling high performance brake fluid is the DOT 4 type.
  9. The DME would need to be programed for the presence of the lights; that cannot be done with the Durametric system.
  10. There are both a sensor and a solenoid on each cam cover that measure and activate the VarioCam unit. As this code could entail either, the best way of diagnosing the problem is to measure the cam deviation and angle values on Bank 1 using a Porsche specific diagnostic tool like the Durametric system, a PST II, or PIWIS. With that tool you can not only see the cam values, but you can also use the software to activate the VarioCam system while the car idles so that you can watch what happens in real time. Based upon that data you can determine if it is the sensor (no values or erratic values), or the solenoid (no cam angle change with active).
  11. Year and model would be helpful, or if the engine is a three chain or a five chain version.
  12. All engines are happier breathing cooler outside filtered air. I would locate the missing parts and reinstall them.
  13. The year and model are always helpful when addressing these questions. For the most part, brake light bulbs for the 986 are P21W for the corners, and W3W for the center. Both are readily available online or from parts stores.
  14. P0507 is a throttle position actuator code, indicating a higher RPM than expected. While intake air leaks will cause similar problems, they typically result in other codes (overly lean mixtures). Your throttle body may need cleaning or replacement.
  15. From what I can find, that pump is only available as a complete assembly, and retails for around $3K: ABS PUMP ASSY - 2001 Porsche 911 (996355955BX) List Price: $3,428.24 You Save: $586.74 (17% off) Sale Price: $2,841.50 Core Charge: $772.84 Genuine Porsche Parts Manufacturer: Porsche Part Number: 996-355-955-BX Part: ABS PUMP ASSY Replaces: 996-355-955-52, 996-355-955-54, 996-355-955-62 Part Notes: 2WD, W/STABILITY MNGMTPARTS: Order by description.
  16. Year and model is always helpful. You would need the car's wiring diagrams. The Bentley manual has a set for most 996's.
  17. Year and model would always be helpful, as would recognition that not all parts are sold separately, either by Porsche or the aftermarket.
  18. Yes, but it is much easier, and can actually be quicker, to drop the engine before starting as you will be doing full cam allocations on both banks.
  19. Current fuel blends, particularly with 10% ethanol in them, can degrade pretty quickly. StaBil makes inexpensive additives that can stabilize ethanol blended fuels for up to two years. Worth a look, we use their "Storage" product on all vehicles put up for the winter here, and have never had one act up in the spring.
  20. Watch for noise or vibration, or torn boots on the CV joints. There is a CV joint at both ends of the axles, under the boots:
  21. Pricing on these cars varies with climate and geography, so you would need to do some research in the area in which you live to get an idea of how they are priced.
  22. First, welcome to RennTech :welcome: As for the value of the car, what a car is worth is what someone else is willing to pay for it. That said, when considering buying a Porsche, you need to shop around to get a feel for the realistic sale prices of the model you are looking at. There are also several online services that will give you some idea of pricing in your area. Some sellers would like to think that a 15 year old Boxster with 75K miles on it is worth $25K because it is clean and they took care of it; I can assure you it is not. Secondly, once you find one in your price range, it is imperative that you have an independent Porsche specialist of your choosing do a complete pre purchase inspection on the car. While a good PPI can run several hundred dollars, the money is well spent as the inspection will reveal any pending issues that will need attention, giving you considerable negotiations leverage on the final price. Good luck in your search.
  23. Easy to tell by looking at it, the OEM plug is silver in color and has an 8MM Allan key way; the LN unit is black and uses a 10MM Allan. I think I know what happened. Some neanderthal did not have an 8 mm allen available so he, or it could be a she i suppose, used a T50 Torx which left its imprint on the soft metal leading me to believe it was always a Torx. Funny thing is it works just fine torqued to spec. Go figure. Some Torx bits closely approximate Allan key sizes, but they are not a perfect fit and will lead to deformation of the plug keyway with usage.
  24. A lot of the Durametric problems with the Cayenne line has to do with the use of Siemens made DME's in those models, which apparently use a different diagnostic logic. From what I have read, VW diagnostic systems, which do not work on other Porsches, seem to do a better job with these cars. I was informed by Durametric not to use VW diagnostics ( such as Ross-tech )on the Cayenne as it can cause CANBUS faults. I have also read that but we have several customers using VW diagnostics (Ross Techs VCDS) instead of the Durametric system on late model Cayenne and seem to have gotten by without problems as far as I know.
