JFP in PA
  1. Not necessarily, the head may be repairable, but that can only be determined once the problem is isolated and actually visually inspected. Leak down tests determine the percentage of pressure that is being lost at TDC using compressed air and special tool: http://en.wikipedia.org/wiki/Leak-down_tester Usually, and depending upon the general condition of the engine (miles, etc.), something in the 10-15% range is considered normal. Often, when a head is cracked, you seen very high leak %, and often get lots of compressed air into the cooling system causing anything from bubbles in the coolant to a water geyser at the surge tank. Similar results can also be had by pressurizing the cooling system with another specialized tool to around 20 PSIG and then see if it hold pressure for 15-30 min. If the cooling system does not hold pressure, it is going somewhere.......... Sorry to hear that the car is a recent acquisition, but this is why having a proper pre purchase inspection done before money changes hands is so important on these expensive vehicles. A good PPI would have caught this.
  2. Pathway forward: Get a leak down test run on the bank that the smoke comes from. Pressure test the entire cooling system. This is not going to heal, it had to be properly diagnosed and fixed.
  3. First of all, several companies make the cooling system UV dyes, including Airlift (see below), who makes the Porsche vacuum coolant refilling system: Secondly, you definitely have the signs of an intermix issue in that tank. From your description of the exhaust smoke, you may have a cracked head.
  4. Might want to look for a Torx socket set (Sears item) in 1/4 or 3/8 drive that can fit into the space:
  5. On cars with factory installed Lits, the auto level check takes place at engine start in relation to the cars attitude or position, on aftermarket installed Lits, it takes place when the lights are turned on regardless of how the car is sitting. Kind of thought it might be a loose or corroded connector. Glad you got it fixed.
  6. Your Durametric should also be able read the last ten stored alarm trips and ID their source as well.
  7. The tool (special tool 9616) is a Porsche "Pin out" or "DME break out" box for testing circuits. Porsche's Black Forrest version is about $2K (if you can find one), OTC makes something similar, but equally rare, called the OTC 3226: This allows you to plug into the DME's wiring harness and test individual circuits electrical properties to make sure they are functional. All in, sells for about $1k.
  8. It sounds like you have a low level current draw problem on the lights, perhaps a short to ground as described. I tried your technique on a similar car that is otherwise fine in a totally darkened bay, there was no illumination at all, and we could not detect any current draw on the light circuit.
  9. Without the code(s) number(s), anything would be a pure guess. Get it scanned, let us know the code(s).
  10. Try manually configuring the car using the Durametric instead of letting go on its own and see if the code is still there. When I do a manual configuration for your car on my system, my header (Pro system, version 6.3.1.7) reads "(2005-2012 Porsche 911 997)". We have noticed that some cars with build dates late in one model year or very early in the next can do some strange things on the Durametric, which may have more to do with Porsche than Durametric. I just had a very late 2001 model year 986 Boxster (one owner car with complete service records, so we are sure it has not been modified) on the system, and if you let it self configure, you get a indication for an ABS system code. But the car is fine, and there are no MIL light illuminated, and a quick scan shows no codes. When we pulled up the car configuration chart, the system had selected ABS/DSC/PSM 5.3, which is correct for a 2001 986. Only problem is that the car appears to have a 5.7 version of the system in it (which would be correct for a 2002 year car), so when 5.3 is selected, Durametric says there is a problem. Change the selection, problem disappears. We don't see this frequently, but it is consistent to specific cars, and as long as you know it is there, it does not constitute any problems with diagnosing or clearing codes.
  11. How much would you be willing to bet? I can take a screenshot :-) But here's a question... Given that I had intermittent right beam motor actions (using the Durametric), and that now the motor is stuck in position. Also given that I have no sensor faults so the control unit should be getting the signals it needs to move the beams up and down....... and given that both motors stick in the lowest position under normal operating conditions..... Doesn't it sound like the control unit to you? It is a reasonable assumption to start there; if you have a buddy with a similarly equipped car, you might want to "borrow" his control unit for a few min. to test as the replacement unit is well north of $100 and cannot be returned. And there is still the possibility that Loren's post tests will still be required as it can still be a servo out.
  12. HBA codes are for the High Beam Adjustment of the Litronics servo motors. I would be willing to bet the codes actually read something like this: HBA 011 Fault2 Engine path, right If that is correct, the Durametric just told you that HBA 01 points to a problem with the High Beam Adjustment on the right side of the car. Typical possible fault causes: Short circuit to ground or open circuit in the circuit between [the] control module and servomotor for HBA, left; servomotor for HBA, right, is faulty; or the the control module itself is faulty. You either have an electrical issue (loose connector, frayed wiring, etc.) with one or both lights, one or more weak servo motors that move the lights, or the headlight control module itself is on the way out. Not bad for $297 diagnostics tool, otherwise you would have needed a PST II or a PIWIS to tell you the same thing, but they cost a lot more ...............................
  13. +1, I think he has the software set to the wrong vehicle description, which will yield strange and/or misleading information with the Durametric system.
  14. We did you refill with the Pentosin ATF-1? To my knowledge, the OEM fluid is still an ESSO product ( ATF LT 71141 fluid) and is the only one approved for 1999-2001 Tip transmissions. There are a lot of aftermarket companies claiming to have compatible fluids, but Porsche has remained very specific on both manufacturer's (Esso, Fuchs and Shell) and fluid types for these gearboxes.
  15. Pentosin is after market, Porsche has theirs compounded to their specific OEM specs. There has been much speculation over exactly what it is, but as it is readily available, works very well, but has a reputation for not being overly compatible with some aftermarket coolants, you would need to be cautious about mixing. As a fresh batch of OEM coolant premixed with distilled water lasts for many years in a clean system, we stay with what we know works,
  16. Do you have the actual code numbers?
  17. Two ways, one using a set of special cable clamp pliers: You can also unbolt the tank from the bulkhead and pull it into the trunk a bit to gain access.
  18. Here is a fairly detailed DIY from the DIY archive at the top of the page, the author chose to use an aftermarket coolant, but it would still be the same for a 50/50 OEM coolant/distilled water mix............ http://www.renntech.org/forums/tutorials/article/301-996-complete-coolant-flush-diy/
  19. Have you checked the TSB archives to see if there is any information about needing to replace both pumps?
  20. I think you are going to find that many shops are reluctant to undertake an already diassembled project; there are always issuse with missing bits, broken parts, etc. that just cannot be figured into an estimate. These are never fun.........
  21. No video that I am aware of, a lot of the TSB's are available at the top of the page to contributing members under the "DIY Tools" tab. The TSB will tell you what it is all about and the new part numbers for the replacement parts, but it is not a tutorial on how to do it.
  22. Could be a fuel pressure issue (the 2005 has an integrated fuel filter in the pump assembly, so it cannot be changed without doing the pump). Easy to test (there is a fuel pressure test port on one fuel rail that you hook a gauge up to for testing). I would get it flat bedded to somewhere where it can be tested.
  23. To my knowledge, there is nothing in changing the battery that will trap the key in the ignition; most likely, you can get that out by moving the steering wheel back and forth while turning it. But as inserting the key activates certain systems, you should not have left it in while disconnecting the battery. Work on getting the key out, make sure everything is turned off, and reconnect the battery; you should be fine.
  24. Moe often than not, problems associated with heat are cable related rather than battery or alternator (in fact, the battery actually becomes more powerful with heat). Usually, loose cable ends, and/or high resistance in the cables from internal corrosion, cause poor cranking or low voltage when hot problems. 996's are infamous for this, and I believe there is a TSB about updated cables to address this specific issue. Not an expensive fix, but requires a bit of time due to how the cables are routed. Heat can also impact the voltage regulator if it is already weak. Fortunately, the regulator is a $40-50 item (get it from VW or online rather than the dealer) and an easy swap with alternator already out. You could have your alternator shop test the entire system and replace what is required as well. We prefer the highest CCA you can throw at the car, simply because it controls how the car will spin over, particularly in the cold. Our standard recommendation for CCA is the 800 amp Optima's.
  25. Try 7198 or 7288
