JFP in PA
  1. Check your drains before it rains, not after when it is already too late...…………..
  2. They are called "earless" boot clamp pliers and are widely used on GM cars, Amazon sells the Lisle version which are quite good for around $20: If you tap down just the crimp itself, it will not loosen the band, we do this all the time. Just don't go nuts on it.
  3. You can tap the crimp down slightly to gain more clearance. The factory clamps use a standard clamp crimping tool, they just lay flatter.
  4. The 1999 996 Carrara would carry a 5.2.2 DME, not a 7.2. A 2000 would carry the 7.2 DME, but again would be subject to the issues mentioned earlier. You cannot simply swap DME's.
  5. The swap you are attempting is complicated; your 1999 car has a mechanical throttle, the 3.2 is an electronic throttle, the 3.2 uses different sensors and sensor communication protocols, if you have the factory alarm in the 99, it will not recognize the 7.2 DME, etc. You will need the 7.2 DME, the entire wiring harness from a 3.2 donor car, the throttle pedal assembly, and you will be doing some creative wiring to tie it all together. Your cooling system hard lines from the engine to the front of the car are a different size than the 3.2 uses, so you will need to either fabricate adaptors, or source the 3.2 hard lines, it also need the addition of the third forward radiator. Then you will need access to either a factory PST II or PIWIS computer to get your car to recognize the DME and visa versa. It is all doable, but it is also a lot of work. Good luck.
  6. I don't believe that is possible, the two DME's are physically different.
  7. I would agree. You only rarely find nothing has moved.
  8. You are going to need to use the 7.2 DME for the 3.2 engine, which may also require you switch to a later dash cluster as well, as the 2001 was already using CAN Bus technology.
  9. At a minimum, it is adjusted wrong; if an adjustment cannot fix it, the damage repair was done wrong..........good luck
  10. The lower one yes, the upper one is very restricted and I don't think you can get a tool on it assembled.
  11. Here is a photo of one of the shaft joints, you can see the bolt hole for the pinch bolt that secures it to the splined shaft ends:
  12. I am not sure the column joints are available as a sperate part, you would need to check with a dealer on that. There are two variant of the lower steering column where the joints are, V2 is for cars with PSM (it carries the steering angle sensor), V1 without PSM. V2 is available as a replacement shaft with both joints, as is V1. Replacing either requires removal of the entire steering column, which is a bear of a job. The joints a both ends of both variants also have a locking bolt that secures the joints to splined ends of the column and steering rack, these can come loose and create the issue you are seeing. You can quickly check the rack by seeing how much the steering wheel moves back and forth without the car running, there should be very little free movement. Only check this after looking at the shaft joints above; if the shaft joints are loose or damaged, you will appear to have a bad rack when you really do not. Good luck.
  13. I would look at two things: The steering column has to u-joints in it that can come loose and/or wear: The second thing I would look at is the amount of play or backlash in the steering rack, which should be very minimal:
  14. Mike, he is dealing with the small metal plugs in the ends of the cams blowing out, not the green cam cover plugs.
  15. 19 ft. lbs. is correct, as is +120 degrees (updated in 2002). Be sure to use new bolts (they are single use only), and apply ARP Ultra Torque lube to threads and under the bolt heads.
  16. Welcome to RennTech It could be as simple as a problem with the bulb in that light, or it may also be a short.
  17. That call is yours, but considering that you need to pull the cam to do this, I would do them all and be done with it, otherwise you will always be worrying if the one you didn't do will be next.
  18. Welcome to RennTech Before going down the LS path, you might want to talk to one or two of the forum members that have done the LS swap; general consensus is that they would never do it again.
  19. +1. As I mentioned earlier, the paper work for the replacement engine says it was installed in 2008 as that was more than three years after Porsche stopped using the second version of the IMS and switched to the oversized bearing, it is very probable that it carries the large bearing.
  20. Afraid you are at a cross road here for multiple reasons. First, Porsche does not sell the plugs as a part, and I am unaware of any aftermarket source. Second, even if you could source a suitable plug, there is no guarantee it would not do this again. The threaded plug is the way to go, but you are going to need to find a machine shop to drill and tap them without blocking the oil passages near the ends. The treaded plug is the “once and done” approach to this problem.
  21. Parasitic drain testing is a common problem on many late model cars, and Porsche is no exception. The process is relatively simple: You attach a multi meter between the positive cable and the positive terminal of the battery, with the meter set om mA. With everything turned off, close the doors and remove the key from the ignition. Your initial reading may be fairly high and it may take the vehicle as much as an hour to settle to its minimum drain level, which should be 40-60 mA. If yours is higher than that, start pulling the fuses one at a time until the drain drops into that range, The last fuse pulled is the circuit with the problem drain.
  22. If the paperwork for the car says the engine was replaced in 2008, I’d bet it is the oversized bearing as it was more than three years after the factory made the switch.
