JFP in PA
  1. That slight a tire pressure difference should not be enough to trigger this problem. More often than not, battery/charging system issues can trigger "ghost" ABS/PSM codes in these cars, so I would start by checking them first. I would also scan the car with a Porsche specific scan tool to see what faults are indicated.
  2. Welcome to RennTech Sunset Porsche is one of RennTech's board sponsors, and very highly regarded within the Porsche community at large. Many poster's here, as well as shops like mine use them almost exclusively for our parts needs without problem. Did you try to contact them to resolve your problem with them?
  3. No, the CPS would totally shut down the engine if it failed.
  4. OK,let’s start with the most obvious: Cracked coils are a problem, regardless of what plugs are used. They need to be replaced. As for the plugs, there are a wide variety of plugs that will work fine in these engines, ranging from the factory Beru to Denso Iridiums, but they need to be properly gapped. Most shops do not have the tools to reset the gaps on multiple side electrodes, so they just slap them in the way they come out of the box. Usually, the Beru’s are pretty close right out of the box and need no changes, which is one reason they are widely used.
  5. A photo would be useful, but it sounds like a line connection that requires a release tool.
  6. It is on the side of the transmission, under the car.
  7. That won't do it, it needs to be Porsche specific (PST II, PIWIS, Durametric System).
  8. The car is behaving as though the anti theft system thinks you are trying to steal it, and is shutting off the fuel and spark. You need to go back over your radio install and look for anything that would lead to this. Do you have access to a Porsche specific scan tool? It would be interesting to see if there is an open circuit somewhere in the security system.
  9. OK, let's try a long shot: When you replace the radio, did you ground the radio anti theft wire? The central locking control unit may be responding to what it thinks is someone trying to steal the radio or the car..............
  10. The only place I would use is Hoffman Automotive Machine, Inc. in Watkinsville GA.
  11. Not a good day. Intermix can come from either a cracked head or block casting, or a blown oil cooler. Pulling and testing the oil cooler is simple and quick, replacing or repairing the head(s) not so much. If it is the cooler, $200 for a new cooler, flush the cooling system a couple of times to clean it out, new coolant and you are back in business. If it is one or both of the heads, it is a bear of a job, and I would start by dropping the engine out to work on it on a stand (doing so is typically quicker than trying to do it in the car). If the head can be repaired, you are still going to pay $1-2K just to fix the head and go through them, which does not cover pulling or refitting the engine, just repair the heads, and there are only a couple of shops I would use for this type of repair. Good luck...............
  12. Year and model please................
  13. The Gibbs DT40 is an excellent street oil, high ZDDP levels, great film strength. We use it extensively in the shop.
  14. The final design IMS bearing tends to fail more on the track than on the street, unlike the earlier design's that did just the opposite, but they still fail with the same catastrophic outcome, albeit it not as large numbers as the first two design bearings. So while the third design IMS was better than the earlier versions, basically, any Porsche with an IMS bearing is at some level of failure risk, with only the level of probability varying, which is why the factory designed the IMS out of the engines in 2009. Cylinder liner scoring is not as widely recognized a problem, and there is little public data collection to point to a specific cause or level of failures. Most seem to point to two suspects: Cold weather and oil. All boxster design engine's can load the thrust side of the piston skirt on start up, and with excess fuel wash of the cylinders in the cold, combined with many modern oils no longer having useful ZDDP anti wear levels, liner wear can occur over time. Interestingly, other non boxster engines such as the Audi's also suffer similar cylinder scuffing, so it is not just limited to Porsche's.
  15. Yes, I would replace it; the water pump is a maintence item, so it should always be replaced. I would replace the chains and get the LN chain tension paddles as well, and I would very carefully go over the oil pump, replacing it if it shows wear. If it is good, I would get the $20 oil pump pressure relief spring and piston update from Porsche, and I would replace the investment cast oil pump drive shaft with the chrome moly unit from LN as well. Basically, anything that could suddenly crap out and ruin an otherwise good day should be done while you have access.
  16. Good move. Also replace your RMS and AOS while the car is apart.
  17. Welcome to RennTech If you have already extracted the IMS bearing from the shaft, you cannot reuse it. The process of extraction damages most of the internal components of the bearings, which will lead to quick failure. If you have not extracted the bearing from the shaft, even though the unit feels relatively smooth means absolutely nothing. I would be willing to bet that there is already no grease inside the bearing, and the seals are hard as well. It would be false economy to not replace it.
  18. In general, dealers will accept your receipts as proof of service, so keep meticulous records. Resetting the service alert requires a Porsche specific scan tool such as the PIWIS or Durametric system. Plastic pans and cam covers are becoming more common with the newer cars. Your oil is cooled by a separate cooler, so the plastic pan should not bother anything. Oil is a "hot button" topic, so while I do agree with the suggested 5W-40 weight, I would choose Joe Gibbs DT 40 due to its high levels of ZDDP.
  19. Your shifter is cable operated, if they become detached at either end, this is what you get. Try looking at the transmission end first.
  20. P0650 is a fault with the CEL itself: P0650 Check Engine Malfunction Indicator Light (MIL) – Open Circuit P0650 Check Engine Malfunction Indicator Light (MIL) – Below Limit P0650 Check Engine Malfunction Indicator Light (MIL) – Above Limit Check wiring from DME control module, pin IV/31, to instrument cluster for continuity. 1. Connect special tool 9637 to wiring harness (DME control module connector). 2. Remove connector X 2/3. 3. Connect ohmmeter to special tool 9637, pin IV/31, and to X 2/3 on pin side, pin 11. Display: 0 - 5 ohms If infinite ohms is displayed, check wiring harness for chafing and pinching damage. 4. Remove connector III of instrument cluster. 5. Connect ohmmeter to X 2/3, sleeve side, and to connector III of instrument cluster, pin 2. Display: 0 - 5 ohms If infinite ohms is displayed, check wiring harness for chafing and pinching damage. Check wiring from DME control module, pin IV/31, to instrument cluster for short to ground. 1. Connect special tool 9637 to wiring harness (DME control module connector). 2. Remove connector III of instrument cluster. 3. Connect ohmmeter to special tool 9637, pin IV/31, and ground. Display: infinite ohms If 0 - 5 ohms is displayed, check wiring harness for chafing and pinching damage. Check wiring from DME control module, pin IV/31, to instrument cluster for short to B+. 1. Connect special tool 9637 to wiring harness (DME control module connector). 2. Remove connector III of instrument cluster. 3. Switch on the ignition. 4. Connect voltmeter to special tool 9637, pin IV/31, and ground. Display: 0 V If battery voltage is displayed, check wiring harness for chafing and pinching damage. If it is a P0605, you have a much more complicated issue, the DME is dying. In either case, more diagnostics are going to be in order, and if the DME is going it is going to be expensive. Good luck.
  21. As long as the O-ring is in good shape, you should not have to replace it. You should lightly lubricate it with some coolant or some silicone when reconnecting the hose to prevent chaffing it.
  22. Another pathway is to spray the flange with a quality penetrating oil such as Kriol, then put a suitable socket over the flat end and use a large c-clamp to manually press them out. Doesn't always work if they are severely rusted, but many just pop out.
  23. These catch everyone out, the hose has a metal end on it with an O-ring, and the wire device is holding together as a locking system:
  24. They are only sold as kits, try searching for someone selling a used kit, or even renting it online.
  25. Welcome to RennTech Year and model are always useful, and a photo might help as well as I am not sure what you are referring to.
