2 hours ago, VinnyO said:
Hello, I just got a 2001 Porsche Boxer handed down to me that’s been sitting for quite a while. I finally got it started and I have lost the radio code. if someone could help that would be amazing. Thank you
CDR-220
Becker 1
type 4462
# Y5046578
24/99
Try 5494
38 minutes ago, Type-A-Hippie said:
Hi There,
I just bought a 2000 Porsche Boxster (my very first Porsche) and the Radio is locked out.
It is a 220 Model Radio, Type 4462, Serial # Y5035876
Hoping that someone can help.
Try 4320
2 hours ago, CandaceBby said:
Hi, im having the same issue. Disconnected the battery and need the radio code.
Dealership provided 4745 but its not working.
1999 911 Carrera Cabriolet
CDR 210
R3297
W5024689
Please help!!!!!!!
4745 should work if that is the correct serial number.
Did you get that serial number using the method in the Lost Radio Code FAQ?
If not, please do so.
If you did then chances are that your radio has been repaired by someone other than Becker. If that is the case I can not help you. Sorry.
  • Thanks 1
9 hours ago, Duy Nguyen said:
I just bought a 1998 Porsche Boxster. Radio version CR-210. Would you please help to pull the code for my radio? Thank you in advance.
Serial number: V5008227
Model number: R3297
Try 1304
  • Thanks 1
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4462
serial # X5028909
Thanks for your help, much appreciated.
2 hours ago, Rebra said:
Hello,
Becker CDR 220
type BE 4462
serial # X5028909
Try 3418
