3 hours ago, sasilverbullet7 said:
Hi, I have a 2001 Porsche with nav.
Can I have the code please?
On the side tag:  FB5WX78004
S/N:  P0804010482503 the last two numbers may not be correct, best I could do at the angle I was looking.
The last two numbers are important.
Try 8734
4 hours ago, Garage_allys said:
Hi, I have a 2001 Porsche with PCM
Vin number : WPOZZZ99Z1S601162
Thanx...
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Thank's for the information....👍
Model BE2582 is PCM.
3 hours ago, Witterings said:
Any chance of getting a code for a CDR 32
Model No. 4667
Ser No. 15000533
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
