20 hours ago, Loren said:
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Sorry .... you say it doesn't take a code, I'm confused. I've owned the car for 18 years and have entered the radio code several times over that period, I unfortunately lost the card recently that it's written on.
I've attached a picture of the radio requesting a code?
Probably me being a bit thick but if you could explain would be greatly appreciated?
Edited by Witterings
The code can only be entered using a Porsche PIWIS tester.
Hi all,
Same issue...
Just picked up this car.
2000 Boxer S
Becker (Original Replacement)
Dead battery, No radio code.
Front of Radio - CDR-220
On the radio the "STAMPED" number is BE4462W5002703
ANY HELP WOULD BE GREATLY APPRICIATED
Thanks!!
1 hour ago, Thor00S said:
Hi all,
Same issue...
2000 Boxer S
Thanks!!
Try 8317
  • Haha 1
11 hours ago, Jon Whitney said:
Purchased a car with a CDR 220 radio (Becker). Radio shows code and the previous owners cannot remember the code.  Model #BE4462  Serial Number W5011714 .  Please research the correct code.
Thank you
Jon Whitney, PCA
Try 8595
