Hi group, I also need help with the radio code. Replaced battery. This is the info that I have: 1999 boxster, CDR-220, type 4462, X5016142. Thanks! I've checked the manual and the card with the code is missing 🙁
Try 9685
  • Like 1
On 2/1/2024 at 6:43 PM, Loren said:
Try 9162
Thank you, BUT 9162 is the original and used to work but in the last 20+ tries it did not anymore. Any ideas why? All help is welcome.
If your radio has been repaired by a third party rather than Becker then I can not help you. The code numbers are reset after any repair so Becker has to either set them then (if possible).
Thank you, I will check.
