Lost Radio Code - post your request here
Hello!
Can somebody help in radio code?
Becker
Typ: IDIS
Model-No.: BE 2580
Serial-No.: x5011775
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
Serial No.: PO80000155232/09
Porsche original number:
996.642.104.03 EFR
Thank You!
Hello!
Becker
Typ: IDIS
Model-No.: BE 2580
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
996.642.104.03 EFR
Thank You!
Please read the Lost Radio Code FAQ -
"These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
Yes, but dealer says, that's not the original radio in the car, so they can't give me the good radio and psm code. What's the next?
Hello!
Becker
Typ: IDIS
Model-No.: BE 2580
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
996.642.104.03 EFR
Thank You!
Hi. I have just compleated a rebuilding a damage Porsche Boxster 1997 ( used 6 mnts) imported from USA to Norway.
I did not receive any paper on this car,so I do not have the code on the RADIO. That is an BECKER CDR 210 -- MOD 2282
Serial Nr. V 5007781 Porsche nr 993 645 120 01
Can someone help me out with this please. :king:
Many thanks in advantage...
Edited by rohtpor
Try 4921
Try 4921
This was perfect, many thanks.. :clapping:
Hello guys. I am planning to remove my cdr 22 because I want to connect AUX cable.
I don't have my Radio Code if something goes wrong. Can someone provide me a Unlock Code for:
Radio CDR 22
4467
Ser.: 15004504
Thanks!! P.S. I am really glad that I found this forum, a lot of interesting stuff! See ya around! :)
