Lost Radio Code - post your request here
Sorry. I did read the FAQ but I missed that. What options do I have then?
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hello and I was hoping you could help me in finding my Radio Code.
Becker 1
4462
Y5039642
Thanks for your help on this.
Try 5940
Loren -
Did you ever have one of those days when you just knew everything you did just turned out perfect?   Today was just one of the those days for me and you capped it off!   I just knew when I got the code from you it would work and sure enough, it did.
Thanks for all your help.  I truly appreciate it !!
Cary
Hello.
  I  acquired a 2000 Porsche 911 C4 with a weak battery. Please provide the radio code so I can replace the battery and use the radio.
Becker CDR-220
Type:  4462
Serial #:  Y5038395
Many Thanks
Hello.
Becker CDR-220
Type:  4462
Serial #:  Y5038395
Many Thanks
