Lost Radio Code - post your request here
16 minutes ago, Loren said:
If 9104 does not work then chances are your radio has been repaired by a 3rd party (not Becker) - in that case I can not help you. Sorry...
Thank you vey much for the effort, I got the radio of eBay from a dismantler, so I don't know if it was repaired.
1 hour ago, Michael M 986 said:
Hello,
I had to change my battery and didn't have a voltage saver and so lost my radio code.  I have a Becker CDR 220 Type 4362, Serial 15050689.  Would anyone be able to help me with the four digit unlocking code?
Thank you in advance.
Try 8585
2 hours ago, Ole Jensen said:
Hi, I need a code for a 996.
Type: IDIS BE 2580
serial: 15079249
Thank you!
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
