JFP in PA
  1. After you clean it the filter canister, use a bright light and carefully inspect it for any impact damage. We have had a couple leak because something hit them and cracked the plastic housing.
  2. No. With the engine running, and the trans in gear, the front pump is running at full pressure and everything is full.
  3. Sounds like a bad misfire, but without a scan and the codes triggering the MIL, anything would be a guess.
  4. By-the-by, did you ever get your RMS straightened out?
  5. Duncan is correct; the only time you would need to pull the third tensioner would be if you cannot get the flange off after pulling the original two, and that very, very rarely happens.
  6. Well, you can try sending your photograph to the dealer's parts department, and maybe they can give you a better answer.
  7. Behind the wheel well liner on that side is the EVAP canister and fuel tank filler. Most likely, you are hearing noise from that. Have a read through this: http://www.renntech.org/forums/topic/33970-strange-whistling-sound/
  8. Try looking here: http://www.sunsetporscheparts.com/auto-parts/2000/porsche/boxster/roadster-s-trim/3-2l-h6-gas-engine/hvac-cat/evaporator-and-heater-components-scat Remember, some parts are not available separately, you may need to buy a larger component to get it.
  9. No. #3 is called a lower control arm, #6 is the track bar. http://www.sunsetporscheparts.com/auto-parts/2011/porsche/cayman/s-trim/3-4l-h6-gas-engine/front-suspension-cat/suspension-components-scat
  10. The Pro version is capable of activating the cruise control system, but the Enthusiast cannot.
  11. Yes, but always use new bolts only.
  12. I'd suggest using board sponsor Sunset Porsche's online parts site ( http://www.sunsetporscheparts.com/ ) to check part numbers for both vehicles; if they are the same, the part is the same.
  13. With the 9A1 engine, the IMS is gone and no longer an issue. Only downsides (customer comments) is the car's race car like ride, which can sometimes get old for everyday use. The car should also have center lock wheels, which can restrict aftermarket wheel selection. The ceramic brakes, while terrific on the road, can get very expensive to maintain.
  14. We have seen a couple, and heard or read about others. While not an everyday occurrence, when it does happen the results are devastation with broken rods and/or crankshafts and split cylinders. Not pretty.
  15. Welcome to RennTech :welcome: It is not at all unusual for some early Boxster to go a lot of miles before the I/M Readiness test clears, we have seen customer's cars go a couple hundred miles before it reset, which is why we caution owners not to try to fix problems, or experiment with diagnostic systems right before going for emissions testing.
  16. Failures of recently installed, and even right out of the box AOS units is unfortunately an all too common occurrence. We test every unit we install, and the one on every car that comes into the shop; some seem to last forever, others not so much, and to date we have found no way to separate one from the other. While a bad or failing AOS can inhale more oil than a good unit, the larger concern is having the engine ingest liquid oil and hydro lock. Long term burning of excessive oil can shorten cat life, but the liquid oil issue is far more critical.
  17. If you have a leaking cam tensioner, they do have crush washers underneath them. That said, you cannot just remove the tensioner and replace the washer, the process is more complicated in order to prevent the cam timing from moving during the process (item # 6 & 12 ) : I would first try torqueing the unit to 30 Ft. Lbs. and see if the leaking stops. If not, the washer will need to be replaced.
  18. While these cars are well known for not liking aftermarket gas caps, you should get a different code (large EVAP system leak) for a bad gas cap.
  19. You need to disconnect the long line under the intake at the purge valve (#1) and canister ends, then blow air through to clear it, I would also check the valve itself, and they have been known to stick as well.
  20. P0446 is typically the EVAP system purge line is blocked, or the EVAP canister itself has high flow resistance. Usually addressed by disconnecting the purge line and blowing it out with compressed air. I think the actual code you are referring to when you say P1133 is actually P1130, which is for O2 sensor adaptation, idle range, bank 2, below limit. If so, this code is indicating that your mixture is overly rich, usually due to a MAF signal problem, high fuel pressure, a leaking injector, or the EVAP purge valve hanging open.
  21. Sure; first, never disconnect the battery to clear a code without first reading it. Doing so loses all of the accumulated systems diagnostic data that could have identified the problem and helped get it fixed. Second, now that codes are back, get the car scanned and let us know what you found.
  22. We have a couple customers running Fabspeed cats, which seem to be working well.
