JFP in PA
  1. Not a difficult job, but it does require removing the axles and re-torqueing them after the boots are done, and not everyone has a torque wrench that goes high enough (if memory serves, the spec is around 360 ft. lb.) You should be able to find both the boots and fresh CV grease as kits online. When the boots are removed, the CV bearings should be cleaned and repacked with the special grease.
  2. Also a thought I had, I can check voltage and ground easily at the connector, but going back to the root of the problem... based on the firing order, coil 4 shouldn't cause such a hard start issue since its nearly the end of the firing cycle right? Which leads me to thinking its a fuel issue as well. Fuel pumps can start to go "on the fritz" and still somewhat function even by testing with the fuse method to isolate them right? Truck has been rock solid before this issue, just trying to keep from throwing money/parts at it. I thought you had already checked out the fuel system pressures and said they were OK?
  3. The code you are seeing indicates that either the trans is slipping, which you should be able to detect while driving, or the trans control unit cannot figure out what gear the transmission is in. This code is often caused by the communications cable between the controller and the gear box often referred to as the ribbon cable) which often leak at the connectors. Cleaning the connectors may help, but if it is too far gone, it is a $350 or so part. It can also be the internal electronics plate on the valve body itself.
  4. As you are not getting a plug misfire code (P0304) for the number 4 plug, I think you have an electrical issue either with the connector or wiring on that cylinder as the code is saying it is getting an implausible signal from that location.
  5. OK, I have got to ask where you keep reading these things. The older 911's had an oil level recalibration procedure (964 and 993), but yours should not.
  6. You could be at the edge of it going off. Clutch wear is always hard to estimate as it is related to driving style. Keep an eye on it, if the pedal starts feeling heavy, or you start seeing slippage, get it looked at. Big issue here is you do not want to kill the dual mass flywheel.
  7. How many miles? Track time?
  8. First of all, yes, ZDDP will shorten the life of the cats, but the larger argument is by how much. Because the EPA has the OEM's on the hook to replace the converters under warranty for up to 8 years or 80K miles, they lobbied the EPA to force lowering the ZDDP levels in an attempt to help them get off that hook. Unfortunately, ZDDP is the best anti wear additive available for engine oils, which means that low ZDDP oils allow engine wear that ZDDP would have prevented. Best part of this argument is that without very sophisticated laboratory analysis, it is not possible to tell if ZDDP or crap gas additives were the cause of cat failure. While nearly no one reveals that actual ZDDP levels in oils these days, UOA's have shown that DT40 after more than 7K miles still has more ZDDP remaining than M1 has fresh out of the bottle. Perhaps a better way to look at the argument is that you as the car's owner need to make a choice between replacing the cats, which only requires some hand tools, or potentially having to rebuild or replace your engine, which is both more expensive than the cats and requires a lot more tooling. I know where I and my customer's fall on that call. You also need to note that if your cats do actually go bad, the car will code and tell you long before you go anywhere near CA Smog.
  9. Probably a leak somewhere in the EVAP system. Do you think its a leak or is it the fuel line vent valve?? Also, i understand why the sound goes away when I step on the gas, but, why on earth would it stop when I turn the AC off? That makes no sense to me. JFP, can you shed any light on that for me?? Thanks Buddy! Because of the location you indicated, it can only be one of two things: The EVAP system, which is just below the fuel filler door area, under the wheel well liner; or possibly the AC coil in the heater box, which is adjacent to the EVAP system behind the firewall. You need to get a stethoscope and try an isolate which one it is, By far, most of the noises we see in this area are from the EVAP system (stuck valves - there are multiple, leaking hoses, canister itself, etc..). As this would be a vacuum leak, it will change volume or vanish with RPM movement.
  10. Our customers have not had any problems with the combination.
  11. If you have both the adaptor and filter to look at, you will find that the adaptor fits nearly flush into the current canister's opening (just a thin lip protruding), and when you add the spin on filter, the combination is actually very slightly shorter than the OEM unit. You will be fine.
  12. Welcome to RennTech :welcome:
  13. Probably a leak somewhere in the EVAP system.
  14. We have changed the filters without any problems.
  15. Sure, why not? When you change the filter, you only lose the oil in the canister, which is less than a liter, so be prepared to top it up.
  16. As Silver_TT pointed out, you have a now rare and very precision built, low production numbers engine, so some of the parts are not going to be cheap; but even so, I would not hesitate to replace that tensioner and everything else on that chain side. We regularly see a number of these cars, many of which get the daylights beat out of them on a regular basis; and I have never seen this type of issue with the Mezger engines.
  17. You will only be changing out the electrical section of the ignition, so no reprograming is required, just a very small screw driver.
  18. Yes, but it gets worse. If you look at the picture of the bearing on the site, in the upper right corner of the photo is a metal punch and a replacement oil pump drive shaft with a slot ground into it. While they don't mention it in the linked instructions, they want you to take a punch and hit it with a hammer to put a very tightly controlled size hole in the plug that keeps oil out of the IMS shaft on the oil pump end, then replace the OEM pump drive shaft with the one that has a slot ground in it to allow oil into the IMS shaft to "pressure" lubricate the IMS bearing. Problems here are that there is no way you are going to use a hammer and punch to put a very specific tolerance hole in anything, and then you are left with a partially flooded IMS shaft, which is going to side load the bearings. Add to that you are replacing the already failure prone investment cast oil pump drive with one that has been weakened further by grinding a slot in it. When the oil pump drive snaps in one of these engines, it is all over as you instantly lose all oil delivery, there is no coming back from that failure. The entire concept leaves me weak.
  19. 1) Yes, definitely. 2) Never heard of it doing that, but if the code is not returning, I would not be concerned. 3) No, a failing CPS will often not code when they are bad. When the sensor fails, the DME simply fails to see the engine turning over, and shuts down the fuel and ignition systems, thinking that the engine has stopped. They are also famous for being fine when cold, then acting up when they get warm as well.
  20. This design has been discussed multiple times on various websites, and there are some questions about the method used to create a passage for how it gets oil, and the long term effects of running the shaft partially full of oil.
  21. I think you are misunderstanding terminology here. The Pelican chain, "without a master link", is an endless chain that requires pulling the engine out and apart to change it, as does the factory chain. It is also not uncommon for some parts to fit many different brand vehicles. In any case, having worked on Turbo's for many years, I really don't see how you are going to change one of these chains, even with one with a master link, without pulling the engine. These cars have very restricted space around the engines, making pulling the engine a real time saver for many such repairs.
  22. I don't know if it is anything in the sensor design, as some seem to go on forever and others only last a limited time. I do know we have had better luck with the factory units than with after market.
  23. Yes, it is possible. Because of all of the electronics on these cars, spurious voltage excursions can lead to all sorts of weird issues. The DME can basically "loose its mind" when it does not have the operating voltage it expects, as can many of the various sensors on the engine. You can test the alternator output with something as simple as a digital multimeter. At idle, the system should be around 14V or so. A load test on the alternator would monitor the voltage output as the electrical load on the system increases, which would give you additional data, but a simple output voltage would be a good starting point.
  24. No. a load test for the alternator is a dynamic process; with the car running, the system ramps up an electrical load on the system as shows how it responds. AutoZone testing is more for "it works or it doesn't work", like a light bulb.
  25. Batteries should get warm, but not hot, which is usually a sign of trouble. I would load test the battery and the charging system as spurious MIL lights are often voltage related. What's the best way to do that You need a system load tester to do this:
