i'm looking at changing the rear main seal on my 2002 996 i have all the tools and access to a ramp,is this quite a straight forward job and is there any step by step guide to this job' i'm quite competant to do this job having worked fo a specialised mercedes benz truck dealer for the last 10 years.
Welcome, have you already tried the search button? This item has already been discussed many times.
These are for a boxster but nearly identical procedure for the 996.
transmission removal
http://www.pelicanpa...RANS-Clutch.htm
clutch/flywheel/main seal
Caution: with the new PFTE seal (997 101 212 01), according to the WSM, it must be dry fitted (no oil, grease or lubrication). It will destroy the seal.
I'm in the process of developing a RMS seal tool for the DIYers, should be ready in a week or so.
I've been told by a local porsche specialist and there is no new type seal is this correct,
I've just found a later type double lip seal part number 99710121200 will this fit into a 2002 996 where it is advertised it says so,I'm not sure if the local specialist know his stuff.
Edited by Gary1320
The original 986 and 996 (first made around 1997) seal has been revised many many times since then..
The latest one I believe is from around 2005-2008ish and is the PTFE seal. Came off the cayenne or cayman if I remember right.
The part number may have been revsied since then, but the seal is the same.
Just be sure to buy the part from a dealer or reputable sources and you will be getting the latest one.
For the 996, this is the latest p/n avialable and the one you should be using.
99710121201
Edited by logray
