3 hours ago, Daniel Rodriguez said:
Good afternoon
New to Porsche. Replaced battery and now looking for radio code. Hopefully thus is the only thing to do when replacing battery..
Have: 1999, 911 C4 with Becker 1, Type 4362, W5010192, 45/98 (??)
Thank you,
Daniel Rodriguez
Try 3289
  • Thanks 1
On 9/20/2022 at 8:25 AM, Loren said:
Sorry, I wasn't sure it would work on such an old radio.
Hey Loren, do you think if I unhook my battery it might reset my radio to where my code would work?
I know I am using the right code I talk to the previous owner. Is there may be a few codes I could try? Thank you so much for the help.
Disconnecting the battery should not make a difference - sorry.
Did you use the procedure in the Lost Radio Code FAQ
If you did not, please do so and repost.
If you did, then it is likely that your radio may have been repaired by a third party - if that is the case I cannot help you - sorry.
Loren,
It’s been 10 years since I posted on here. Hoping you can help me with a lost radio code.
CR-220
M- 4632
Ser - W9002514
it could also be W5002514 as my pixels are going bad on that bottom row.
thanks so much!
50 minutes ago, ruf965 said:
Loren,
CR-220
M- 4632
Ser - W9002514
thanks so much!
Try 9832
