hi,
Becker 1
type: 4367
24/99
sn: Y5021236
THANKS,
KJ
Try 2450
or
2448
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
none of these worked :(
i also got a code from the local dealer based on the VIN,, didn't work too!
Chances are someone changed out the radio and did not update the serial number information.
Did you try getting the serial number using the method in the FAQ?
i got the SN from the display by holding TP until 'BECKER 1' shows up then i used the right dial.
You can try the suggested varying the number I gave you by one or two each of the first code and see if you can find it.
Just takes patience because of the time out after every three trys.
2451 BINGO!
thanks a lot :)
2451 BINGO!
thanks a lot :)
Having the same problem, cold winter, battery went dead, please help:
CR220/CDR220 not sure which one
4462
W5006256
In need of radio code.
1999 Boxster
Edited by Bev
Hello,
Looking for a radio code on a:
2001 Boxster
CDR220
Becker 1
X5019010
Thanks in advance
Try 7809
or
7807
Thanks Loren for the fast reply! quick question
but it still wait now
PLEASE READ THE FAQ - that is explained in the FAQ.
