Click here to Donate
  • Replies 16.3k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Try 0369
From the Lost Radio Code FAQ... I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again.
Try 4761
Posted Images
Hey Loren,
I searched thru other post but could not find a solution.
Radio Code Issue after battery replacement:
2002 C4S
Becker1
4362
#15004153
24/99
Problem is...radio only says "MUTE" and does not ask for a code...which I don't have anyway..
It allowed me to get SN's and radio type after holding TP but then returns to MUTE when radio is turned OFF and ON...
Any suggestion?
Thanks a million!
jon
Link to post
Hey Loren,
2002 C4S
Becker1
4362
#15004153
24/99
Any suggestion?
Thanks a million!
jon
Did you try pushing the volume button? that turns mute on and off.
For your code
try 0968
or
0966
Link to post
Hey Loren,
2002 C4S
Becker1
4362
#15004153
24/99
Any suggestion?
Thanks a million!
jon
For your code
try 0968
or
0966
Thanks Loren for the suggestion.....It was not the MUTE switch....
When I replaced the battery...I was hoping that if I R & R'd the Battery quickly enough with the help of another person (<30 sec), maybe there would be enough capacitive charge or luck to avoid the radio code issue....
I'm not sure what happened but looks like the radio "locked up" in "MUTE" mode.....Volume/Mute switch would not toggle between Mute and Volume states.
At any rate, I re-disconnected the battery, waited 60 sec's and reconnected.
The radio then asked for the codes, I entered and everything is back to normal.....
Many thanks....
I suppose the radio locked up with my initial quick battery change.
It would not go out of MUTE display initially no matter what I did.
jon :D
Link to post
Loren -
2001 Carrera 4
Type: CDR220-Cassette
Mod: 4362
SN: 15040443
24/99
Thanks - this is a huge convenience!
Try 5048
or
5046
Loren - these don't seem to work. I checked the serial # again and it is correct. Is there another code(s) I should try?
Link to post
Loren,
Great job on the site. I've read some many of your posts. I've run into the same dead battery issue. So after having all that fun looking for the hood release without jacking up the car, I now need the code for the radio. Much thanks in advance.
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Link to post
Loren,
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Try 0643
or
0641
Link to post
Loren,
2000 996 C2
CDR-220 CD
Ser# Y5035648
Type 4462
24/99
Try 0643
or
0641
It worked perfectly. Thanks again.
Link to post
Dear Loren,
I noticed your helpfulness torwards other members on their request for the reset codes I hope that you might be inclined to help me too? :)
Becker
type: CCR 220
Model: BE 6624
Serial: 15002956
I miss my tunes ;)
Thanks in advance
-Monica Baligad
Link to post
Dear Loren,
Becker
type: CCR 220
Model: BE 6624
Serial: 15002956
I miss my tunes ;)
Thanks in advance
-Monica Baligad
Try 4677
or
4675
Link to post
Please help with radio code. Becker 1, Type 4462, Serial 15001759.
Try 2539
or
2537
I tried those two codes as well as 2533, 2535, 2538, 2541, all no luck.
I actually have a 996, not a 986. But I don't think it should matter.
I will try a few more combinations tomorrow night (three wrong inputs and I have to wait an hour before I can try another three times), but I might be in the unlucky 5% where the program doesn't work :(
Thanks anyway! :renntech:
Edited by Galun
Link to post
  • Similar Content
    • By larry meucci
      Installed a new alpine radio to replace my factory Porsche radio I kept the factory Bose sound system and the factory steering wheel controls still work!
      I think it looks pretty nice, very ecstatic about the new radio look.
      Easy to do
    • By Ayasick
      When I turn the radio on, all it says is 'wait'. How do I get to the 'code' screen?
      I have a type 4462
      Serial # 15077232
      What would the code be to unlock radio?
      Any help would be appreciated, thank you!
    • By Nick Radloff
      Hello. This is my first time posting as this is my first issue with my 2006 Cayenne S and this is also my first Porsche. The vehicle had an aftermarket radio in it when I purchased it and I changed that radio for another one that supported Apple CarPlay. both units are made by pioneer and after looking at the backs of them it appears to be plug and play. I changed everything out and fired it up and everything was great. No issues or errors and the sound worked fine and calls worked fine. The previous installer used only twisted ends and electrical tape to secure the wiring so I took the wiring apart and used wire nuts to make sure nothing came apart while it was being installed and for longevity. After starting the car back up, I received a brake proportioning fault and an oil pressure fault and it told me workshop fault as well. I pulled fuse 40 as I heard it resets the system and plugged it back in. The brake proportioning fault is gone but the oil pressure fault remains. I double checked my wiring work to make sure that I was not missing anything and nothing had come back apart. Everything is indeed attached and plugged in.
      Now that I have finished my long-winded story, was this fault caused because I knocked something loose or because I left the fiber optic cabling unplugged for too long. I noticed that there was a red light coming from the input and of the fiber optic cabling a couple of times while I was rewiring it. Do I just need to reset this system using a better method or do you think something is wrong with it?
      Any help would be appreciated and I intend on donating to this forum and website as it seems to be a true source of knowledge and help for the DIY Porsche enthusiast. Thank you in advance and I look forward to your responses.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
  • RennTech.org Store at Amazon.com
