Lost Radio Code - post your request here
CDR-220
Type 4462
Serial 25014726 (Z50147526? It looks like a 2 on the display, and I haven't pulled the radio to check the back)
Please read the Lost Radio Code FAQ for how to double check the serial number through the display.
If you think you read it correctly then
Try 1304
Thanks Loren. Finally needed the code today, and unfortunately 1304 doesn't work. Serial #25014726 was read off the display as described in the FAQ, I was just unsure because most serials seemed to start with a letter. Is there another code I can try?
CDR-220
Type 4462
Try 1304
I used the later one (ending 7526).
Using Serial #25014726
Try 5041
